-   -   Weird problem (http://forums.pelicanparts.com/porsche-911-technical-forum/1012836-weird-problem.html)
classic911 11-11-2018 10:55 AM
Weird problem
Turn the ignition key and starter starts to engage immediately but car never starts...never had this happen before. Thoughts?
Bob Kontak 11-11-2018 12:55 PM
First, what year is the car?
Second, based on the info provided, you are out of gas. (I wonder why I have no friends?:D)
Have you done any maintenance recently? Has it sat for a while? Has it been running differently?
proporsche 11-11-2018 01:29 PM
are you turning the key over the spring or just so the light on dash comes on?
If yes your el.portion of ignition switch is bad...
Ivan
classic911 11-11-2018 02:18 PM
1982 911sc. Literally just turning key just a wee bit engages the starter. Car is full of gas.
jlex 11-11-2018 02:22 PM
Check for spark at the plugs.... Use an inductive timing light on a wire, or pull a wire and ground it against the engine while someone cranks the car for you. Don't get shocked in the process. :eek:
proporsche 11-11-2018 02:28 PM
again ......do you turn the key over the load spring??????
Your car has no DME relay that is from 1984 Carrera models only...
Ivan
ossiblue 11-11-2018 05:43 PM
Ivan
Ivan
I gather from your last post that the starter engages as soon as the key is moved from the vertical position, long before it reaches the far right START position. If so, I agree with proporsche, problem with the electrical portion of the ignition switch. If not, you need to make that clear.
LM3929 11-11-2018 05:43 PM
If you turn the switch to the start position does it start then?
It sounds like the electrical part of the ignition switch is no good.
Lorne M.
