Cold runner
I have a 68' 911E 2.0 that refuses to reach normal operating temperature (170-180 'ish) The gauge does move but the warmest I have been able to get the car is 150. Runs like a dog. .Any ideas? Bad gauge? Previous owner states the car would reach operating temp of 175.
I suspect the car has an intake leak, actually I am fairly positive it does. Would this cause the car not to warm up fully. I am in Seattle so the temp is normally close to 50 during the day. .
I have performed the following work on the car.
plugs
wires
cap
rotor
condenser
oil change
Any ideas would be greatly appreciated!
Alan
_______________________________
68' 911E Targa
Old 03-10-2003, 11:28 AM
I should add, the previous owner stated that the car would run well at 175, but that is just what he said. .. .
Thanks,
Alan
Old 03-10-2003, 11:31 AM
does that model have an internal oil thermostat? you could be running rich thus keeping the engine cool.
i would not trust a 34 year old gauge, but maybe when summer comes she'll heat up the extra 25 degrees.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-10-2003, 11:57 AM
Not sure if it has an internal thermostat or not, I was hoping someone would know. But you are right, a 34 year temp gauge is not to be trusted. I wonder if I should switch to a thinner oil and see if that helps in out.
Old 03-10-2003, 12:13 PM
i would do a search on the internal stat. i would assume it does.
it sounds like it is stuck open. so maybe if she can get hot one time, she'll start working again.
Old 03-10-2003, 01:32 PM
Looks like Pelican only lists a part for 74 and up. . . I will keep checking.. . Thanks.
Old 03-10-2003, 01:40 PM
