Thanks guys Mike and Kevin, I get the gist of what you are saying and its helpful for me to get started and plan the work while "I'm in there"
I'm not the copy cat kind of guy, but I don't re-invent the wheel every time either.
www.ahhgaragetime.com
Old 01-21-2019, 12:33 PM
This week I finally got under the car to finish the gusset plates for the rear coilovers.
This threaded started by fabricating the typical coilover bracing visible in the engine compartment, but there are vulnerable places under the car where the cross member attaches to the frame rail.
Here are the plates I added to the under side:
While I was down there, I added the plates between the torsion tube and seat pans as discussed in this thread too.
And I boxed in the weak anti roll bar mounts and also ties them into the torsion tube.
In summary these are the chassis upgrades I completed:
1) Seam Welded Frunk Area
2) Rear Coilover Gussets (engine bay)
3) Front Shock Tower Top Plates
4) Front Strut Brace Brackets
5) Front ARB Strengthening Plates
6) Rear Coilover X-member Under Plates
7) Rear Torsion Tube to Body Plates
8) Rear ARB Boxed in Mounts to Torsion Tube
Did I miss anything? I do plan on a custom rear roll cage.
Here's the link to this weeks video covering 6,7, & 8
Old 02-02-2019, 10:57 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
Nice job once again Tom!
A couple things come to mind:
1. Nice job beefing up the sway bar mounts. Your bracing should definitely prevent the flexing that causes the base to tear away from the mount. Also, keep in mind that sometimes the welded nuts pull through the base. So you might want to plate the bottom to reinforce that area? But since you already stabilized the mount, you may not need to fatten up the base.
2. When you do your custom rear cage design, you might consider touching down some diagonals through the seat pan onto the torsion bar tube. "Easiest" (easier said than done) is to connect the bars to the trailing arm pivot point. I know your plates connecting the torsion bar to the seat pan address this. But we've seen the torsion bar housing crack the sheetmetal around the spring plate bushing area on coilover cars. So anything you can do to support the torsion bar housing is a benefit.
Some choose to plate the area around the outboard end of the torsion bar housing like Elephant's sheetmetal reinforcement kit
https://www.elephantracing.com/porsche/911/chassis-reinforcement-for-911/#prettyPhoto
But I think if you can get the torsion bar well supported with something really sturdy like cage bars, that's an even bigger benefit?
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 02-04-2019, 07:48 AM
I did add these big barrel nuts inside the rear anti roll bar mounts and they are tacked at the top and bottom. I hope these don't come apart.
This idea came from another Pelican member, but I can't remember who, sorry.
Old 02-04-2019, 05:44 PM
fast eddie
I took the easy way out and just ordered mine from Tarett Engineering
Ed
Old 02-04-2019, 08:07 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Nice. Those nuts aren't pulling out of the mount!
Kevin L
Past: '87 Carrera
Old 02-06-2019, 06:13 AM
Walt Fricke's Avatar
I've never had a nut pull through a rear sway mount. I did have a nut inside a boxed mount break loose. I drilled a hole through the boxing so I could poke at the nut while getting the cap bolt snugged, which has worked OK enough that I've not contemplated opening up, rewelding, and closing back up.
Isn't going to happen here, for sure.
Old 02-09-2019, 12:01 AM
Old 02-09-2019, 02:45 PM
