External Thermostat Testing
Hello Pelicans,
I am currently rebuilding my external thermostat and wanted to run my test results by you. 1. Drop it in a pot of water. Notice the circular plunger is flush with the cylindrical end of the thermostat unit. http://forums.pelicanparts.com/uploa...1543172106.jpg 2. Bring it up to a boil. http://forums.pelicanparts.com/uploa...1543172106.jpg 3. Plunger goes up about .400 inches. Does this look like acceptable travel? http://forums.pelicanparts.com/uploa...1543172106.jpg 4. If you drop it in the housing, the plunger holds the unit up and exposes the slots through the port shown here. I am guessing in this condition oil is allowed to pass through the lines and front cooler. http://forums.pelicanparts.com/uploa...1543172106.jpg Lastly the plunger stayed up after the unit cooled. I was able to push it back down with finger pressure. My guess is in the housing, while hot, the plunger will overcome the spring pressure to raise the unit, but once it cools down, the spring pressure will push the plunger back into the unit, lowering the unit and covering the slots, and prevent oil flow through the front cooler until the temp goes back up again. So what do you guys think? Is this unit still good? Thanks in advance. |
Oil T-Stat.
What prompted the re-build?
Gerry |
Been awhile since I pan tested one. How did it operate on the car? I like to use a infared gun to read temps.
One thing I recall doing on one that I noticed was sticking was polishing the plunger and bore where I saw some scuffing. No sticking on re-test. Not sure if yours is designed to come apart though. I seem to recall mine having a large circlip. |
Thermostat worked fine beforehand. Just testing as a sanity check while Im in there. |
don't know the cost but why not just replace it and not worry.
any problems getting the hoses off the Tstat. |
Thankfully no issues removing the hoses. Removed all the lines as a unit, lots of penetrating oil, heat, and wrench clearance to get them off with no damage to either the tstat housing or the lines. |
| All times are GMT -8. The time now is 04:50 AM. |
