Valvoline VR1 New Bottles/Packaging
So I was at Autozone the other day and got 20 qts of VR1 20w-50. Half the bottles were the old packaging and half were new. They read pretty much the same and the guy working there said it’s just a new label. Looks like the same exact oil and I doubt they changed the formula but wondering if anyone knows anything more on the story
I’m currently using and can’t tell any difference. I even ordered more online and what was delivered were all new packaging. Again, I’m not concerned just wondering if anyone know anything additional.
2007 GT3 RS Orange/Black
1986 911 Carrera White (dedicated race car #23)
Old 04-28-2018, 04:20 PM
DerkPerk's Avatar
It is just the packaging. This last fall AutoZone was clearing out the old inventory for $1 a quart in preparation for the new style. Plenty of us stocked up.
Old 04-28-2018, 04:58 PM
DWeg1998's Avatar
Kendall just did the same. New packaging is more red, same oil.
If I had the choice at the same price I’d buy the new. Since you got some of both, I’d use the old bottles first, but you’ll be fine here.
Old 04-28-2018, 05:32 PM
Wildman Emeritus
I stocked at $.65 last Fall. Cheapest oil change ever. I see prices are back to normal with the new label.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 04-29-2018, 08:21 AM
Ah man, the title had me all excited for a repeat of the $1 sale.
The oreilly stores have $25 off $100+ and sell it in 5 qt containers https://www.oreillyauto.com/detail/b/valvoline-5149/oil-16865/motor-oil---racing-19421/1eb4e849cac7/valvoline-20w-50-motor-oil/race20505qt/4773331
1984 911 Coupe
Old 04-29-2018, 08:32 AM
sugarwood's Avatar
I have made the switch to Synth and don't ever plan on using Dino VR-1 again.
Who runs non-ZDDP fortified Synthetic oil that is not 20w-50?
1986 Bosch Icon Wipers coupe.
Old 04-29-2018, 09:56 AM
I’ve heard Valvoline advertise on the radio that they have a new bottle that pours more easily.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 04-29-2018, 12:10 PM
SCadaddle's Avatar
Yes. They do. I bought one of the 5 quart jugs at Walmart the other day to change the oil in my Subaru. It's got a BIG opening with a curved lip. Makes it a LOT easier to just pour oil on EVERYTHING. I was cussing the obvious MIT graduate that conceived this brilliant new design. Don't plan on tightening the cap too tight when you are done. The only upside I noticed was a "pull ring" to remove the foil seal.
Old 04-29-2018, 12:16 PM
I was under the impression that California was upset about the API designations on the old bottles, since the high zinc formula is hard on modern catalytic converters. It looks like the lawyers added some wording.
1981 911 SC
2013 Mini Cooper JCW
2017 GMC K1500
Old 04-29-2018, 12:49 PM
I moved from Brad-Penn 20W50 (a partially synth oil) to Valvoline VR1 20W50 Racing and the engine uses less oil...
Old 04-29-2018, 10:46 PM
Are you using VR1 conventional or synth?
Old 04-30-2018, 03:50 AM
kjchristopher's Avatar
$25 of only good on home shipping, and the oil doesn't qualify for home shipping when I click the link
Old 04-30-2018, 04:44 AM
We have confirmation that Valvoline VR1 has changed formulations. This has happened along with several other changes. We have already heard that Brad Penn is going to have to change because Lubrizol is discontinuing the additive package that Brad Penn has always used. This is due to the new API formulas designed to combat LSPI. Both Brad Penn and VR1 used a sodium detergent, which is bad for LSPI. As such, all of the additive companies are dropping formulas that contain Sodium because of the LSPI problems.
I'd recommend anyone running VR1 or any oil that uses the now discontinued Lubrizol sodium based package (like Brad Penn), to do used oil analysis to confirm that your choice of lubricant is performing as well as the older formula.
We switched away from ALS and helped to start Speed Diagnostix so we're biased as to what lab to use.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 12-04-2018, 06:32 AM
175K911's Avatar
Charles, as always you're a wealth of knowledge about the oils our air cooled engines need. With Wally W's recommendation for the 3.6 I just built with his magical head work, I just got a case of Joe Gibbs Driven from you. How does their formulation stack up against the new Penn Grade (formerly Brad Penn, formerly Kendall)
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 12-04-2018, 07:10 AM
Omg!!just use the Porsche classic oil!!! Made for our cars. Or keep using deep purple, brad penn, Mobil 1, Kendall, Castrol, rotella!!! A few months ago I switched to Walmart 20/50 at about $2.83 a quart. Motor is using less oil. Really. My car has 160,000!miles on it. I bet it will
Go 100k more!
Old 12-04-2018, 08:09 AM
We switched to Driven after Jake and I got involved years ago and helped them formulate their product line for both aircooled and watercooled Porsche models.
Like with the VR1 formulation change, those choosing to run the Penn Grade product are going to have to test their oil and quantify that the new formulation works just as well as the old one.
Anytime we have done a formulation change with the Driven oils, we've always tested it in our engines before those changes were pushed out to the production line. We get buckets of test oils we loving refer to as "secret sauce" that we put in our own fleets of vehicles. That's why we are fans of Driven. We know what goes into it developing it because we help do the development.
Charles Navarro
Old 12-04-2018, 08:13 AM
Manufacturers have all opportunities to “tweak” their additive package, with or w/o a labeling/packaging redesign. There’s always the potential of upsetting customers if they suspect quality is compromised. Once upon a time Castrol was THE go to lube. No mas - although their ads try to maintain some semblance of their storied history in racing.
BTW, seems like some folks rank low oil consumption higher than lube quality, or ....... all things being equal.
Sherwood
Old 12-04-2018, 11:08 AM
Brap
tmaull's Avatar
Given the relatively short oil change interval most of us are using in our cars, I'd be more concerned with zddp and other Extreme Pressure additives than with the detergents. I'll run some lab tests on my oil and post the results, but I'm not expecting to see much difference in the SIG or wear metals.
1980 911SC Coupe 3.4
1995 Miata
2005 Tacoma
2009 Street Triple
Old 12-04-2018, 11:31 AM
Under the radar
Trackrash's Avatar
I'm not sure what the deal is with VR-1. It used to be that there was two or three versions. Looks like it is just one now?
Speaking of detergents, the two times I used VR-1 my oil got dirty very quickly. Noticeably dirty after less than a 1000 miles. It was my understanding at the time that the VR-1 racing oil had less detergent and more anti foam for racing and should be changed after every race. I assume that is no longer the case.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-04-2018, 11:47 AM
Under the radar
Trackrash's Avatar
OK, so a quick Google search and I am still seeing different versions of VR-1. There is a synthetic version, a synthetic blend, and I am guessing a conventional?
Anyone have any current info?
And there is a 10-60?
Gordon
Old 12-04-2018, 11:50 AM
