1974 2,7 Cold Start Valve
Hi there,
i don't seem to figure it out .
My 1974 CSV valve has plastic tube to connect to fuel line. Apparently part number is 911.606.101.02 but no longer available anywhere.
The new part 911.606.107.01 has different connection and is for newer models.
I was thinking if maybe the older part 911.606.101.00 up to '73 would fit a 2,7 1974 but i don't get it figured out....
2.7 WITH 917K PERFORMANCE
Old 11-29-2018, 02:16 PM
Old CSV to new CSV conversion using banjo eye fitting.
Originally Posted by Jakke Bursch View Post
Hi there,
Jakke,
To connect the new CSV (911.606.107.00/01) to your current ‘74 CSV fuel line, you simply need a 8-mm banjo eye fitting. Search for 8-mm banjo eye fitting that will fit to your existing fuel line and use crimp or Oetiker type clamps.
Tony
Old 11-29-2018, 06:21 PM
Tags
1974 911 cold start valve
