-   -   windows roll up/dpwn module (http://forums.pelicanparts.com/porsche-911-technical-forum/1014387-windows-roll-up-dpwn-module.html)
1ricardo 11-30-2018 01:53 PM
Dear Friends
I wont to install a window roll up/down module on my 1983 911 targa
I would like to the windows go down ( a little bit) when I open the door and for the window go up again when I close the door
Does any only know a window module that do this job?
I actually found one but my electrician told me that the window switch on the 911 rest on a positive wire and mostly of this module require a switch that rested on the negative wire
Does this affirmation makes any sense? Is he correct?
Thanks you all
Ricardo
Reiver 11-30-2018 03:52 PM
The later 911 (83 on up I believe) convertibles have this feature so it should be doable if you source/find the right door mechanisms.
