For my 82, which came with thick flange stock items, Iím going with thin flange SSIís because a) they were affordable and b) I should have replaced my exhaust studs when heads were rebuilt but didnít see it at the time. Relevant here because the studs are somewhat eroded and a hair to thin at their tips to torque 8mm nuts. But where they were once covered by the thick flanges, they are ok.
I bought stainless O2 sensor bungs from SUMMIT, which my sonís friend TIGíd in for me. John
Old 12-07-2018, 08:44 AM
That O2 Sensor bung is located to read only one 1 of 3 cylinders. Maybe should have installed it further downstream as per factory (which monitors the entire bank).
Sherwood
Old 12-07-2018, 10:46 AM
Sherwood,
Bloody good point! Stupid me....didn't even see that.
Others....don't make my mistake.....John
Old 12-07-2018, 12:03 PM
Sherwood,
No worries. Threaded plug, another bung and welding is relatively inexpensive. Be aware there's a preferred installation angle.
Sherwood
Old 12-07-2018, 03:49 PM
911T '72
DeRRis's Avatar
And it's usually done on the left hand SSI.
Dennis
Good drivers have dead flies on the side windows. (Walter RŲhrl)
Old 12-08-2018, 01:15 AM
DeRis, I was waiting for someone to fall into my trap about that: I also put one into the left header AND in the right location(!). That will be primary; the right will have a stainless male bung capping it and was just added for future diagnostics AND because I'd bought two fittings. I'd originally marked it for the "correct" location (after the collector)but made my ill-fated relocation to avoid the oil cooler or something like that. Oh well.
Old 12-08-2018, 04:39 AM
If you have a thin flange engine, can you replace the studs and put thick flange SSI on?
Old 12-08-2018, 08:05 AM
Only because of the factory harness connector.
Otherwise, mount the WB sensor (and it's dedicated harness) on either side. Your preference. Mixture should be the same on both sides, yes?
Sherwood
Old 12-08-2018, 08:57 AM
pete3799's Avatar
yes
Pete
79 911SC RoW
Old 12-08-2018, 09:20 AM
You can also mill down the backside of the flanges on the heat exchangers. There is a thread where someone did that. They also cut off the collars that protrude from the thick flange SSI and goes inside the exhaust ports, I donít think the earlier thin flange engines had reliefs to accept them.
_______________________________
1982 911 SC 230,000mi and counting
Old 12-08-2018, 01:31 PM
