-   -   Which sending unit to use? (http://forums.pelicanparts.com/porsche-911-technical-forum/101524-sending-unit-use.html)
code7rpd 03-10-2003 09:20 PM
I just got an oil pressure/temp gauge for my 81 Sc. The gauge is from an older 911 and has numerical values for the temp in degrees and pressure in psi. I have the correct sending unit for the temp but I don't know which one I need for the pressure - the gauge goes up to 140 psi. Does anyone know from what year 911 I need a sending unit?
Thanks.
Barry2 03-10-2003 10:52 PM
That sounds exactly like the one I have from a '70 911S.
Best,
Barry
Barry2 03-10-2003 11:17 PM
You can also look for a date stamp on the back of the instrument. My oil temp/press combo gauge has a triangle with the number 31 inside the triangle below the apex, then below the 31 but still within the triangle are the numbers 10.70 meaning Oct, 1970.
I have seen this same dating system on the tach from my '73 914 (7.73) and on my '86 930 Turbo tach (10.86).
BTW: 31 in the first example is not the day of the month as my turbo tach has 787 in this location.
Good luck,
Barry
code7rpd 03-11-2003 06:51 AM
Thanks for the help!
