Bill Douglas's Avatar
Big performance increase 911SC
I swapped out the heavy 17" Carrera Cup fakes for the factory fitted 16" wheels.
Wow, the car feels so much faster, responsive, snappier, the list goes on. I loved the look of the 17" wheels with big rubber, but all of that extra rotating mass was not good for the car.
911SC Sport with 930/10, cams and SSIs.
see www.lyallbaybeach.co.nz
Old 12-11-2018, 08:26 PM
Banned but not out, yet..
RSBob's Avatar
That is so cool that you got that kind of gain.
Makes me wonder about my Linea Corsa 17” 7s and 9s.
Bill did you reduce the tire size as well or just the wheels?
Made of matter, but not that much
Old 12-11-2018, 09:02 PM
… having to install spacers to kick out those wide 17 wheels that the Carrera and 930 suspension design did not need to do to such a large extent I suppose that makes sense. Boy if you can feel the difference on your 930 motor then a non aspirated 3.0 SC stock with 17's /wide rubber must really be a slow boat in comparison. What particular stability and control issues has this move corrected ? also in what range does the 'much faster' factor come into play …. taking off or acceleration ?
antares
fatnwide - uncle dave
79 All steel wide body Targa / euro 915 oil cooled LSD / SSI's / RUF 8 & 10's / light flywheel plus lots other silly mods n upgrades
Old 12-11-2018, 09:13 PM
aircooled pegasus's Avatar
The SC/Carrera looks so proper with 16s.
Those fake Carrera Cups are quite heavy also.
Old 12-11-2018, 09:44 PM
madcorgi's Avatar
I'm a fan of running stock-sized tires on my car (1985 Carrera--205 and 225s), though I have swapped out the original 6&7 x 16s for aftermarket Fuchs 7&8x16s with the stock rubber. Just because I like the looks . . .
IAMPARTOFTHERESISTANCE
https://forums.pelicanparts.com/porsche-911-technical-forum/1022378-yes-its-another-white-911-build.html
Old 12-11-2018, 10:31 PM
The circumference is the same but the back ones went from being 245s down to the stock 225 in width. I just think the fake Carrera Cup wheels were SO heavy.
It might be placebo effect, but the car feels more lively, more responsive. More acceleration I would say. Haha, easier to park too instead of muscling the steering wheel around.
Old 12-11-2018, 10:57 PM
Mike964_61's Avatar
You should have weighed the wheels so you would have an actual number. I would have like to known the difference.
Old 12-12-2018, 03:47 AM
Behind the Sun
Scrub Radius. The answer. No black magic, butt dyno or witchery
Old 12-12-2018, 03:59 AM
T77911S's Avatar
my 930 has 18's. I sometimes wish it had the 16's for performance but the 18's look awesome
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 12-12-2018, 04:07 AM
Bill Verburg's Avatar
Just changing from 17 to 16 is no guarantee that you will experience and improvements
It's all about tire OD and the weight of the rotating assembly, tire OD is potentially the most significant and tire weight is more significant than wheel weight which is more significant than rotor weight which is more significant than hub weight.
Judicious choices can make a big difference
here's on example using only 1 tie line, Bridgestone RE71, 16s vs 17s. No change in scrub radius
Here the 17s are going to be ~1.7lb-ft better, for acceleration ~.6 lb-ft worse for braking and also provide better grip in the corners
Bill Verburg
Old 12-12-2018, 04:32 AM
It is strange you can feel in in the seat of your pants.
My 85 came with 15 inch Fuchs, 7s and 8s. It is pretty much impossible to find good performance summer tires that can be used on the highway for long road trips in the 15 inch size. I finally gave up and bought some Euromiester wheels. Pilot Sport tires have orders of magnitude more grip for cornering, and work great in the rain. I did not notice any set of the pants difference in acceleration.
For sure the 15s are lighter that the 17s I have now, but I sure like the driving feel of the 17s.
42 Year member of the Porsche Club of America
Old 12-12-2018, 06:03 AM
W/o knowing details of you specific case I can only guess, but here goes
stock 7 & 8 x15 Fuchs w/ 185/70 & 215/60 tires changed to Michelin PS2(no data on PS) on Euromeister 7 & 8 x17
There would be only a small ~4.6 lb-ft difference, every one is different but that's likely to be not very noticable. But on others changes i've seen far larger differences up to ~45lb-ft
Bill Verburg
Old 12-12-2018, 06:31 AM
Turbo Powered Snow Blower
Based on the title I was sure you added a turbo.
Derrick
Old 12-12-2018, 07:38 AM
Nossir.
Moment of inertia (and weight)!
This is what Bill felt when he switched from his heavy 17" wheels to the original 16" ones.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-12-2018, 07:41 AM
having to install spacers to kick out those wide 17 wheels that the Carrera and 930 suspension design did not need to do to such a large extent I suppose that makes sense. Boy if you can feel the difference on your 930 motor then a non aspirated 3.0 SC stock with 17's /wide rubber must really be a slow boat in comparison. What particular stability and control issues has this move corrected ? also in what range does the 'much faster' factor come into play . taking off or acceleration ?
He has a non aspirated stock 3.0. I think the engine code is confusing you 930/10 simply denotes a ROW 911SC engine.
_______________________________
1982 911 SC 230,000mi and counting
Old 12-12-2018, 08:02 AM
This
Ass-engine Nazi slot car -- PJ O'Rourke
Old 12-12-2018, 08:31 AM
My77 930 felt more nimble when I lost the Ruf 17X9/10s and put the fuchs 16X7/8s back on. Lot less railroading too.
206 637 4071
Old 12-12-2018, 08:45 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Read the OP and then scanned down to see (I KNEW he would respond!) Bill V's input on this. He was of great help when many of us switched our SC race cars from 18" (very light) CCW wheels with 275/35 Hoosiers to 15" Jongbloeds with 275/35 15's.. We did the same with our E class 3.2 cars, the gearing is changed across the board, similar to running a 7:31 R&P. Acceleration out of corners was improved and it changed our cars from virtual 4 speeds (on all tracks I frequented) into 5 speeds..There was a substantial running diameter difference in these two tires, doubt if going 17" to 16" on a similar tire would have the same or even similar effect?
Gary R.
Old 12-12-2018, 08:54 AM
T77911S's Avatar
my brothers 930 still have 16's, we have not raced much but I think he is quicker.
also, my car sits much higher than his, especially in the rear.
I have 285-35-18 in the rear.
Old 12-12-2018, 08:57 AM
Hopefully that is a 285/40 x18, @24.8" OD that is a sweat rear tire only ~.1" taller than a 245/45 x16 and w/ roughly equal inertial cost, hopefully w/ 245/35 or 255/35 fronts for matching balance.
Bill Verburg
Old 12-12-2018, 09:11 AM
