removing rear bumper 77 targa
I have removed bumperettes
to repaint the bumper for the holes I filled..i thought it best to reove the entire bumper instead of working around the trim bits, reflector etc with alot of masking tape. I ve partially removed rubber strip (cant get end near wheelwell to unscrew..or is it just a friction mount? Next..o just remove bellows and then unscrew the 4 bolts holding the \bumper to the absorber or is there more to this then meets the eye? Thanks |
Yes, four nuts holding the impact bumpers to the bumper and four nuts holding the bellows to the bumpers
disband
as I recall the last couple screws are recessed and behind the little black plugs in the rubber trim strip.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Got them off last night, the bellows put up to most fight...cant wait to re-install!
ended up everything off and refurbished, once painted and clear coated, re installed but this time with the bellows in the proper position verus what dpo did.
