-   -   Need help identifying (http://forums.pelicanparts.com/porsche-911-technical-forum/1015836-need-help-identifying.html)
yuth 12-17-2018 12:28 PM
Hi
Anyone knows where is this tube connected to. It runs from the back of the engine. 79’sc
Thanks. http://forums.pelicanparts.com/uploa...1545078303.jpg
gazzerr 12-17-2018 06:28 PM
Trace it back and see if it connects to the front or rear of the throttle body. It's probably either the hose for the vacuum advance or retard on the distributor. There's a number of small vacuum lines back there. Is it connected to a t-connector on your deceleration valve there? I can't quite make it out in the image you posted.
yuth 12-17-2018 06:55 PM
Gazzerr
It connected to the T connector. It’s one of a two vacuum line from the T.
proporsche 12-18-2018 02:01 AM
here is your answer......
http://jimsbasementworkshop.com/CIS/...cuum-lines.jpg
yuth 12-18-2018 03:44 AM
Originally Posted by proporsche (Post 10287666)
Thank you sir.
yuth 12-18-2018 04:13 AM
Another question.
I have read the threads regarding decel vale deleate. Can you please educate me which lines to disconnect and cap. Thanks.
gazzerr 12-19-2018 06:41 PM
Sorry for the slow reply. Check this thread. It's the go to for CIS here. Hopefully it will answer your question. I'm not too familiar with the pre 80 CIS.
http://forums.pelicanparts.com/porsche-911-technical-forum/758788-cis-troubleshooting-dummies.html
