-   -   Vacuum Control line question (http://forums.pelicanparts.com/porsche-911-technical-forum/1015901-vacuum-control-line-question.html)
yuth 12-18-2018 07:32 AM
Hi
I need some help here please.
79’sc . Under the vacuum control. There is a line separate by a T connection. One end connected to the throttle body. Any idea where another end connect to? My is disconnected by accident while I’m working on removing the heat blower. Thanks. http://forums.pelicanparts.com/uploa...1545147143.jpg
T77911S 12-18-2018 08:02 AM
it goes to the thermo time valve (TTV) if you still have one. it is a small black device with an electrical connector going to it. the other side goes to the WUR (warm up reg) should be on the side.
proporsche 12-18-2018 08:07 AM
as previous post...i have a feeling that the T connector should not be on the bottom but on the top..as shown on the other post..look
http://forums.pelicanparts.com/uploa...1216224749.jpg
here is another look at it notice no 11. and 14 is your T ..on top lines.........
http://img.pccreation.net/photos/201812181717235288.JPG
yuth 12-18-2018 08:59 AM
This is my TTV.
This one on the right goes to the T connector at the top of decel valve. Any idea?http://forums.pelicanparts.com/uploa...1545152290.jpg
yuth 12-18-2018 09:07 AM
I have T on the top and also the bottom. I look at most of the diagrams . It goes one way to the throttle. That’s why I’m so confused .mhttp://forums.pelicanparts.com/uploa...1545152523.jpg
yuth 12-18-2018 09:20 AM
The bigger pic. The line with the blue mark is the one I refer to. http://forums.pelicanparts.com/uploa...1545153595.jpg
SkiVT 12-18-2018 10:09 AM
Take a close look at the path of your lines. The line from the center of the TTV should go to the decel valve. The line from the outer edge of the TTV should go to your WUR. Your lines appear to be opposite of that setup (see the diagram posted in response to your other post). It matters at cold start up as the TTV holds off vacuum.
Is the other line in question connected or want to be connected to your distributor? I am not saying it should be but I also don't see another line in the cobweb of lines in your picture that would come from the distributor to a vacuum source at the throttle body.
proporsche 12-18-2018 10:11 AM
as i said and pointed out ..i do not remember T fitting on the bottom look here.....
Ivan
http://forums.pelicanparts.com/uploa...1362681273.jpg
SkiVT 12-18-2018 10:14 AM
+1
This is a great picture
T77911S 12-18-2018 10:19 AM
i was thinking it was off the top too but I have not looked at one in years
you should have 2 large hoses, one goes to a port above the throttle plate and the other goes to one below it. this is how it bypasses air around the plate.
you should have a smaller hose that goes to a T, one end goes to the TB below the throttle plate and the other end goes to the TTV then WUR.
there is a screw adjustment on the end of the DV. that adjusts how much vac is required to open the DV. I would suggest not adjusting it.
you CAN test the DV with a hand vac pump. it IS good to know about how much vacuum it takes to open it, then check engine vac at idle and make sure it is lower than the amount needed to open the DV.
you can also remove the DV and plug the 2 large ports on the TB and then connect the TTV line directly to the TB.
you might enjoy driving it that way.
T77911S 12-18-2018 10:20 AM
that is how I remember it.
you should not be able to blow thru it when it is closed
yuth 12-18-2018 11:17 AM
So the red line should go to WUR and the blue to decel valve ?
http://forums.pelicanparts.com/uploa...1545160440.jpg
yuth 12-18-2018 11:19 AM
Ivan
Ivan
That’s why I was so confused.
SkiVT 12-18-2018 11:25 AM
Yes but it may not matter until you get the T at the decel valve straightened out.
yuth 12-18-2018 01:38 PM
T77911S
So if I want to remove Decel valve. I’ll need to cap Red and Blue. And Yellow connect to TTV ?http://forums.pelicanparts.com/uploa...1545169103.jpg
SkiVT 12-18-2018 04:45 PM
Assuming the picture labels are correct, which I believe they are, the answer should be yes.
Do you have a line from the distributor or not? The original line in question seems like an unanswered question.
yuth 12-18-2018 07:02 PM
http://forums.pelicanparts.com/uploa...1545188494.jpg
yuth 12-18-2018 07:05 PM
Skivt
Yes I do have the line from the distributor to the TB (blue line). I’ll switch the lines on the TTV as well.
SkiVT 12-19-2018 02:48 AM
Maybe the line went to cruise control, based on this pic.
http://forums.pelicanparts.com/uploa...1545216425.jpg
T77911S 12-19-2018 03:45 AM
for the hose to the dist.
there should NOT be vacuum at idle.
the vacuum should be there just after you come off idle.
you want the vacuum advance to start advancing as soon as you come off idle.
you can look at the ports on the TB and see were they are in relation to the throttle plate and then you can figure out which one goes where.
you can verify it with a timing light.
check it with and without the vac hose connected and you will see it working. you will also get advance from the mechanical advance but not as much early RPM's.
BTW, doing this stuff is a great way to learn and understand your car.
those are really nice pics BTW.
