-   -   Cht sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/1016012-cht-sensor.html)
porschedavid 12-19-2018 10:44 AM
Cht sensor
i HAVE 1984 3.2 CARERRA.
Trying to get the CHT sensor out of the head.
Soaked it in wd40 still wont move,
Scared to put to much pressure on it just in case it snaps or strips the thread.
Does any know if it is easy or not to snap or strip the thread. or am i ok to put more pressure on undoing it.
GH85Carrera 12-19-2018 11:05 AM
If it is the original CHT from 1984 is has been in there a long time. Cut the wire, and use a full socket with a quality tight fit. Not some cheap Chinese socket. It will come loose with a pop. You will need a CHT socket to get the new one seated properly. Or cut a long slot in a cheap Chinese socket.
porschedavid 12-19-2018 11:14 AM
I have cut the wire off.And got a socket on it just scared case i snap it or strip the thread
smokintr6 12-19-2018 01:08 PM
I think all the heads have a provision for a CHT, right? I'm not suggesting it would be desirable, but if yours breaks off, or strips the threads out, it wouldn't be the end of the world to wire in to a different location. It's been a minute since I've looked at the heads though (thankfully, knocks on wood)
DanielDudley 12-19-2018 01:25 PM
Put the socket on it and remove it with authority.
http://forums.pelicanparts.com/porsche-911-technical-forum/752223-cht-sensor-snapped-off-head.html
smokintr6 12-19-2018 02:11 PM
Originally Posted by DanielDudley (Post 10289455)
That’s how I wish I would have treated my ex wife...
porschedavid 12-19-2018 03:31 PM
Cht sensor
If worst comes to worst and i have to drill it out,Does any one know is it a blind hole or does it go though to some where.
smokintr6 12-19-2018 04:43 PM
I’m pretty sure it’s blind, going from memory... look at the holes on all the other heads, should be able to see exactly what you’re working with
tmaull 12-19-2018 05:16 PM
I’d at least try some pb blaster for a few days.
86 911 Targa 12-19-2018 05:41 PM
PB Blaster.
Yup!!!!!
Gerry
