915 tranny cooler fitting type
Hi everyone. I have a ROW 84 Carrera and when I put stainless brake lines on I believe I wore a teeny tiny hole in my tranny cooler. I patched it up OK with JB weld and some other bandaids but I know it's not forever. I was thinking about getting a new one, but ideally a cheaper option is running a small universal cooler. I know some people have definitely done this. My question is how do I convert the fitting of the euro cooler coil to something like a 6 AN fitting? Does anything know what these fittings are called?
Old 02-11-2019, 08:59 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Get it repaired:
Pacific Oil Cooler Service, Inc. - Home
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 02-11-2019, 09:22 AM
Perpetual Reassembler
2jmotorsports's Avatar
+1 for Pacific Oil Coolers. They rock!
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 02-11-2019, 09:34 AM
kevingross's Avatar
There was a shop making up adapters for 944-series transmissions, 9xx-parts, very similar to your needs, perhaps identical (I don't have the 915 parts on hand to measure). Unfortunately the part no longer appears on their web site. Alternatively, check out this solution that Rennlister came up with: the lower item in the photo is identical with the 9xx-parts item, if memory serves.
I'd love to hear back as to whether Pacific Oil Coolers can repair the loop. The material is thin, will be something of a challenge to TIG.
Good luck!
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 02-11-2019, 11:47 AM
Vintage Owner
Jack Stands's Avatar
You might check with mb911 to see if Ben might be able to weld it up for you. He’s quite the artist in repairing parts.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 02-11-2019, 12:08 PM
Good luck!
Silver solder, at the temps and pressures in the system it would be plenty. Letting Pacific use the appropriate medium would insure success. It’s crazy for a few hundred(?) dollar repair, vs a homemade kludge, risking a very expensive overhaul/replacement. If the gears and shafts get hot enough, pretty sure they are expensive paperweights. Maybe Matt M. could chime in.
Old 02-11-2019, 12:09 PM
