Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Battery recomendation please.
After only two years, and 1800 miles of service
the dealer/Porsche installed battery does not seem to hold a charge after 24 hours of non-use. 1. The alternator is outputting 13.8V. 2. The battery shows 12.4 volts after 36hr 2A charge. 3. The static current draw test shows 20ma. Any thoughts on a replacement battery? I have used Sears in he past with no such issues. Thanks in advance. And best of holidays to all. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Hi Gerry -
Only 2 years is surprising/unfortunate. I got an Optima Red Top battery (75/25) in 2011 - no real issues. It ran about $170 back then. I do keep it on a minder in the winter. This past summer I did not get to drive her as much as I used to and the battery was let down - I had a little trouble trying to get the cheap trickle charger to wake it up but I finally succeeded. Maybe I am getting close to needing a new one. I have gone a week or 2 recently w/o charging since that event. Happy holidays to you too.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Interstate batteries is where I'd go. Any local shop should be able to get one.
2 years is way too soon for a dead battery. Definitely have it tested to see if it's a shorted plate. You should charge it and disconnect the battery for 24 hours and then see if it held it's charge. |
Dealers response.
I was advised by our local dealer:
1. If the car is driven less than 60 miles/day and/or not placed on a "trickle" charger, the battery will not be under warranty. 2. How this relates to "not holding" a charge eludes me. 3. The Sears battery I previously had never demonstrated these symptoms under the same usage profile. Have a look at the price for one of these factory boat anchors.
I got 7 years from a Bosch battery in my 986. That was the longest life ever and probably a fluke. 5 yrs is typical.
2009 Cayman PDK With a few tweaks |
Whatever brand battery you buy, make sure to buy an AGM (absorbed glass mat) battery. They typically have close to twice the life of the old style flooded acid battery. Also AGM's can't leak acid and can be placed in most any position. I have used them for years. Initially more expensive but over the long run a better buy.
Check the comparisons between AGM and Lead Acid in this article: https://carfromjapan.com/article/car-maintenance/best-car-battery-review/
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 12-20-2018 at 12:03 PM.. |
I'd go along with uwanna's advice. Have installed AGM's in my BMW X3 & the Porsche and they both seem to be doing well. Make sure any charger you have can work with an AGM battery, though.... they're fussy in that regard.
Read about advance glass mat batteries on the 'net... Actually, you may have to go with whatever battery they give you when you have them honor the warranty on the dealership battery. Two years is pathetically short and should be a warranty item.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow ![]() |
I just bought a replacement battery this week for my Targa. I got a group 49 AGM from a flaps (O'Reilly) for $185. Part number is 49PLTJ
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 |
I installed a group 48 agm battery in my '86 targa a few years ago and it's still going strong. The Group 48 size is a bit shorter (and lighter) than the Group 49 battery, making it easier to install/access. I have driven/started the car in sub-zero conditions several times and have never had an issue with the Group 48's slightly lower power rating. Significantly, our 911 battery trays are pre-drilled to hold both the Group 48 and Group 49 batteries, making the install of a group 48 battery a "turnkey" task (don't need to build/buy the adaptor necessary to retrofit in an optima)
Burnin' Rubber
Uuugh those 49s are always b*tch to install.
---------------------------- '84 911 '95 840Ci ---------------------------- |
Costco now sells interstate batteries. I got one last yr for the 911but have had them for my other cars. On the mdx the warrantee was a 42 month one and at 40 months the battery died. No questions asked. Brought it in and got a new one. Only charge was the difference in battery price from 3 yrs ago till now. Something like $5. Turned out it wasn’t the battery not holding a charge as the new one also drained in a week. It was the Bluetooth module circuit staying on, default position when the unit fail, go figure. So I spliced in another relay and all is fine I think I was charged about 110 or so for the battery and a $15 core charge
ken 87 targa |
I did not see the 60 miles/day requirement - it seems quite high. Out of curiosity, what type of battery is it? These days Porsche replacement batteries are AGM if I am not mistaken. Optima states that maintained batteries can last 3x as long as a flooded battery (potentially up to 10 years)
I have an O'Reilly AGM battery in my truck that I drive about once a month, I check the battery voltage each time before I crank it up and find the AGM stays at 12.5V or so over 4-5 weeks without a maintainer. AGMs are great!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
I just replaced an Optima in my 911 that had been in service since 1999.
Pretty good value IMHO so I have no difficulty about recommending them with one caveat: these should be on an AGM-capable tender when not in daily use.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Duracell Ultra Platinum AGM Group 48 Battery
1986 Bosch Icon Wipers coupe. |
A couple of years ago I replaced the monster Group 49 size battery that had gone bad with the smaller "near Group 48 size" battery from the local Autozone, otherwise known as a Duralast T6-DLG. It fit the factory spot in my 82SC like a glove and the hold down bolt/bracket fit the hole in the chassis just like it should. For what it's worth, the battery was made in Germany, I rarely drive my SC and let it sit in my garage for weeks or perhaps more than a month without any kind of trickle charger, and this battery spins the starter up to crank the car with authority.
You asked, that's my choice, and they are readily available. |
Maintenance v/s Maintenance free battery.
Guess I'm hijacking my thread.
Any thoughts out there on the subject matter? Never have used a maintenance free battery. Thanks in advance, Gerry
That's fond- just deglaze
Hi Gerry- Huge fan of the Bosch AGM S6585B- Group Size L3/48. Fits perfectly in the second (short battery length) screw hole and has the added safety benefit of Absorbent Glass Matt (AGM). As Summer generally takes place on a Tuesday up here, I have to pull the battery from Nov-April. I'm going on 4 years with this one, I just slap on the trickle charger occasionally during her downtime.
Missed Approach Petra- 1986 Coupe Last edited by Missed Approach; 12-30-2018 at 12:26 PM.. |
Gerry -- think the AGM battery (which is maintenance free) is the way to go for our 911s -- unlike flooded cell batteries, it truly is maintenance free - see, e.g. https://batteryuniversity.com/learn/article/absorbent_glass_mat_agm
That's what I get from Sam's Club. Put them in my BMWs and Porsches.
Bryan O. 77 930 88 Carrera cab 14 535i M Sport |
Thread Tools | |
Rate This Thread | |
