Tell me about this oil cooler
Car came with it. I assumed it was a factory part until I saw the hole hacked in the front valance.
W. Washer bottle relocated, so is the brake fluid overflow bottle.
What do I have?
1973.5 911T
Old 12-21-2018, 11:46 AM
Been here a while
looks like the air conditioning condenser
Found a period correct hotrod motor, but still looking for 1972 911t motor, 6121622
Old 12-21-2018, 11:49 AM
Do you have any better pictures? Hard to tell what I’m looking at. The last one looks like the AC condenser and protective cover from a later car.
_______________________________
1982 911 SC 230,000mi and counting
Old 12-21-2018, 11:50 AM
walt's Avatar
If you have an SC the oil cooler would be a trombone shaped tube in the front right wheel well.
Walt
82 SC
Old 12-21-2018, 11:57 AM
Looking at the front valance and his signature I doubt that’s an SC
Old 12-21-2018, 12:01 PM
1980 911 SC
Isn't that the blower for the front condenser? Its part of the A/C unit. The PO may have cut the hole to allow for more air to enter blower thinking more air would blow over condenser.
Life's a Beach
Old 12-21-2018, 12:31 PM
SCadaddle's Avatar
Press the horn button. See if it plays this 'un?
Old 12-21-2018, 01:51 PM
Sorry if I appear I know nothing about the early 911's, it's because I don't... And very few in my area to ask.
The last two photos posted upside down.
The AC condensor is attached to the underside of the hood/bonnet.
1973.5 911T
Old 12-21-2018, 02:15 PM
Vintage Owner
Jack Stands's Avatar
That’s an auxiliary AC condenser with the blower in the front trumkblowingdown through it. The oil cooler is under the passenger’s front fender in front of the wheel.
84 Targa
70 914-6
73 914-6 2.7 conversion
75 GMC Motorhome
Old 12-21-2018, 02:27 PM
Here is a good resource to see what parts do what, how they are connected and part numbers. https://www.porsche.com/filestore.aspx/download.pdf?pool=multimedia&type=download&id=porscheservice-originalparts-dropdown-kat074-911-73-katalog&lang=en-us&filetype=default
Old 12-21-2018, 03:39 PM
Originally Posted by QueWhy View Post
Very helpful! Many THANKS!
Old 12-21-2018, 07:52 PM
Pelican has some good Technical Articles on their Porsche 911 (1965-1989) Technical Articles page.
Porsche Air Conditioning Frequently Asked Questions page is good as well with additional links to explain the AC equipment and history. The early AC systems were dealer installed.
Old 12-21-2018, 08:18 PM
Mark Salvetti's Avatar
Also, about that oil cooler in front of the passenger side front wheel - I'm pretty sure that in 1973 it was an option, and a T may not have come with one from the factory. So you may not have that on your car. Although with AC it is more likely you do. Should be the trombone style (looped tubing).
Mark
1979 911SC Targa
Old 12-22-2018, 05:59 AM
I'll try to steal some garage time later today, raise it up and have a better look.
Old 12-22-2018, 06:22 AM
3rd_gear_Ted's Avatar
If that fan is non-operational, the A/C system, condenser side of the circuit is not protected as designed. Over pressure can occur
1980 911SC
Fiberglass Turbo Flares F&R with a 3.6L conversion
869#
AKA "Gemma"
Old 12-22-2018, 09:38 AM
Great info. Pelican is a excellent Porsche information source.
Old 12-22-2018, 03:20 PM
A Fact. Mine was a real hack job.
1973.5 911T
Old 02-13-2019, 04:07 PM
‘84 911 3.2 Coupe
Arne2's Avatar
The A/C in my '72 was factory installed, confirmed by CoA. Not hacked, all the holes are nice, factory quality.
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
1972 911T coupe
Priors - '84 911 Carrera coupe, '84 911, '73 914 2.0
Old 02-13-2019, 04:32 PM
My COA confirms a factory AC also but stuff like SAE bolts, USA hoses, butchered holes for hoses and the front tow hook hacked off and almost perforated the front pan.
1973.5 911T
Old 02-13-2019, 05:04 PM
‘84 911 3.2 Coupe
Arne2's Avatar
That's odd. My car did not have a front tow hook at all, and I've gathered that was normal for early cars with factory A/C. Much of what you describe doesn't sound factory, or at all what I've seen in mine so far. My install is definitely tidy, with perfectly round stamped holes, and is very professional looking.
1972 911T coupe
Old 02-13-2019, 05:32 PM
