Scart Sport Sound Mufflers- Affect Horsepower?
Does anyone have a Scart Muffler 2 In 1 Out/Sport Sound or Silencer 2 In 2 Out - Dual Tailpipe 70MM Rear/Sports Sound installed? Aside from the sound and fit, are you happy with the performance after installation? Have you noticed any loss of horsepower? I have a 2.4L with SSI stainless exchangers I'm considering installing one on.
Thanks Mike |
Hi Mike,
I had one on my 2.7 hot rod motor, I felt that I gave up some mid range for some top end but that was gut feel, but I couldn’t hear myself think most of the time when driving with that muffler on the car so who knows ![]() Cheers, Harry. |
Realize that recorded sound files are somewhat useless since playback levels can be adjusted from quiet to loud. A reference point is needed.
I suggest loading a sound pressure or decibel (dB) level app onto your smart phone, then show those numbers so a more accurate sound level can be reproduced on the receiving end. Sherwood |
Another video for you below. Cheers, Harry. https://youtu.be/5AaQk5j7ROs |
I recently installed a SCART Super Sound 2-in-1-out on my 3.0L SC with SSIs. The Exhaust was modified by SCART to work with the larger displacement. I found that I gained mid-range and top-end power. The sound is to die for. YMMV.
You might lose your hearing from the sound pressure levels.
I measured over 100dB with the Porsche RSR at the most recent LBGP. If you're not wearing ear plugs at 100dB, you're a better man than I. Sherwood |
