73 914 steering wheel in a 86 911
Hi y’all! I need to find the right part to get my 914 steering wheel... part number 914 20347 20809 20 00 to work with my 86 911 backdate.
Any links or part numbers or PM’s cause you have an extra one laying around would be greatly appreciated!
DB
Old 12-23-2018, 06:44 AM
PCA7GGR's Avatar
No can do - 911 steering column spline changed in '74. To use a 914 or early 911 steering wheel on your '86, you need to retrofit your steering column, if its possible, to an pre-'74 one.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 12-23-2018, 08:19 AM
I have a 914 steering column that is complete if you are interested.
Old 12-23-2018, 08:57 AM
Or drill it to fit a momo hub.
Old 12-23-2018, 10:48 PM
M491Cabriolet's Avatar
I have everything needed to see what you can or can’t do. Lemme check and I’ll report back ASAP.
Old 12-24-2018, 04:39 AM
Thank you all for the input! Looking forward to a solution. If not, at least a for sale thread!
Old 12-25-2018, 07:24 AM
That is an old wives tale. Porsche used the same splines on the steering column for all models (911,914,924,944,964,968,993) until they went to water cooling.
You probably still have the plastic adapter for the 914 column on the back of the steering wheel. If you remove it, it is identical to a 911 wheel of the same year.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 12-27-2018, 08:03 AM
I can tell you with no old wives around that the 924 and 944 are smaller bores and spline count. The 928, though, I believe is the same. Additionally, I think there is a difference in length of the steering shaft after 1973, but the bore and spline count are the same...
Old 12-27-2018, 10:08 AM
cycling has-been
bkreigsr's Avatar
Originally Posted by M491Cabriolet View Post
I .....Additionally, I think there is a difference in length of the steering shaft after 1973, but the bore and spline count are the same...
...taken a step further, that means your knuckles will be hitting the gauge eyebrow every time you try to turn anywhere past 30 degrees. ... That, plus, the eyebrow grew about 2 inches toward the driver in '74. The solution is to add a spacer, but that puts the wheel closer to your chest. - not an option for me.
BTDT.
Bill K
Old 12-27-2018, 11:56 AM
