Targa_PB_78_SC
mike sampsel's Avatar
Oil leak from JB weld external
I used tenactin spray to confirm my oil leak source.
It’s from my external case defect mend (second time).
Wonder if anyone had luck patching over the existing JB weld. This type is not so easily removed.
Old 01-13-2019, 09:36 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
My buddy used this on his Audi, hit a parking curb and cracked the pan. Drove the car for years afterwards.
https://markal.com/products/oyltite-stik
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-13-2019, 11:14 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Acetone softens/loosens cured JB Weld when soaked for long enough - you could wet a piece of rag with it and then place it on the case spot (maybe holding it in place with a piece of wood jammed in, etc) . . . rewet the rag a few times and you will eventually have no trouble removing the JB.
Old 01-13-2019, 02:02 PM
Targa_PB_78_SC
thanks for the reply guys
Old 01-16-2019, 08:25 AM
Mike Billings's Avatar
I googled tenactin spray to find out what that is so now I have to look at targeted ads for jock itch for next few months. Thanks for that.
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 01-16-2019, 09:39 AM
Targa_PB_78_SC
Mike, Sorry to hear your crotch is a target for advertising
On the leak, I tried three applications of acetone. Although, it made some come off, I could see it would be a while. I went with wire brush wheel on the old JB, copious amounts of carb cleaner and a heavy layer of new JB weld epoxy. (It was what a guru recommended). It’s all good so far. No need to apply tinactin as yet.
Old 01-16-2019, 03:55 PM
