-   -   3.2 engine harness - engine drop? (http://forums.pelicanparts.com/porsche-911-technical-forum/1016601-3-2-engine-harness-engine-drop.html)
shawn908 12-27-2018 07:52 PM
I aim to post a thread on this unexpected project resulting from my f!$&#!g mistake tomorrow. Tonight I’m searching for info. Found a lot but not clear on: is it required to drop the engine to replace the engine wiring harness?
I suspect yes but hope not.
Thanks for any heads up on experince others have had.
Dan J 12-28-2018 01:28 PM
It might be easier to remove the engine but definitely not necessary
You'll have to remove the alternator and work around the intake
You'll also have to get the starter wires and reverse lights from underneath
A big pain in the butt but definitely doable
shawn908 12-29-2018 07:34 AM
Thanks for the reply. I'm hoping it can be done (by me) without engine drop.
Then I read this while searching/reading - a wareaglescott thread, quoted from a 14Dec2018 post by timmy2 "Engine and transmission out, and everything comes out the back."
I though my fuel line replacement of 2018 was a challenge (...but then with this forum, Len/BoxsterGT lines and advice it got done). Not confident on electrical as impending post to demo why...
yelcab1 12-29-2018 08:09 AM
do the engine drop, you'll be happier. If you are good with it, you can drop it in 2 hours.
scottrx7tt 12-29-2018 10:14 AM
No need. If you need room, just drop the rear down about 3-4” just make sure you unhook the shift coupler. The intake isn’t that difficult to remove either. You probably need to replace the intake gaskets anyways if you have never done it.
Johnr352 03-31-2024 01:34 PM
Following up on this old post. It appears I've fried some of the harness on the left side of the engine from shorting the O2 heater wire and ground wire... It seems I need to remove the harness and fix some damaged wires. This post is helpful but I'm wondering if there any more specific tutorials on how to do this?
Thanks in advance.
ErrorMargin 03-31-2024 05:15 PM
What year is your car? On my 1984, it looks like the O2 sensor goes into the body DME harness.
If this happened to me I’d have to pull the harness from the engine bay to underneath the driver seat…repair and then reinstall.
nospiners 03-31-2024 06:22 PM
no need to drop the engine, remove the intake and its all there. replace intake gaskets and new spacers at the same time and you're good to go
Johnr352 03-31-2024 06:47 PM
Thanks very much to both of you. Mine is a 1984. So pulling the intake will give me access. I’m hoping enough to inspect and repair the harness. I’ve heard pulling it through the tunnel is hard.
I’ve seen a couple of images of motors where it seems there is a connection between the engine harness and the main wire that connects to the DME and relay. Is that later (or earlier) model cars?
Johnr352 03-31-2024 06:48 PM
Have you done this? Any tricks to make this a bit easier?
Tippy 04-01-2024 10:52 AM
This
I can drop mine really far down without removing, but I have no heat or AC to deal with.
ErrorMargin 04-01-2024 06:40 PM
I have not pulled that harness from the car.
However, as I do have the engine out of the car right now, I made you this video:
https://youtube.com/shorts/DLIs2S2ncAM?si=DX4XWol_uPw7s5pp
If I were in your shoes, I’d check the continuity of all the DME wires from the engine bay to the DME connector.
If only a few were bad, I’d think hard about running separate new lines just for the bad wires from the engine bay connection points and then splice them in right at the DME connector.
Johnr352 04-02-2024 12:09 PM
Thank you VERY much for this and agree. My thinking of my process is:
- Undo the harness connections on the left side of the motor to see how much access I have to inspect.
- Try to access the bracket/clip holding the harness in the front of the motor to help give me a bit more harness length to inspect and test. What else can I do here to get more room on the left side? Maybe remove the fuel filter and lines right here? Remove the Intake (ugh).
- Try to replace/ repair bad wires
- Test continuity from each sensor to the relay and DME.
- Determine if the harness needs to be removed.
- Replace (at least) the O2 Harness
- Replace any other sensor wires independently, as needed.
Other considerations?
ErrorMargin 04-02-2024 04:01 PM
My thoughts:
1. Disconnect all wires on the DME harness from their various connection points in the engine bay, this will include the injector control, O2 sensor, etc, etc. See this link for a list of everything that the DME harness connects with that you will need to disconnect.
2. Disconnect the harness connector from the DME....now all wires are disconnected at both ends...hopefully this only took an hour or two to get to this point
3. For each wire...
3a. Check that it has continuity from the front of the harness to the back using a separate wire you run from front to back outside the car just for the purpose of testing continuity. For example, let's say you pick the first wire (let's call it wire A) in the harness to test. Connect a test wire to the end of wire A where it terminates in the engine bay. Run that test wire back to the DME (run the wire outside the car, just laying on the ground) and then connect a small battery and light to both the end of the test wire and the end of Wire A where it terminates in the DME connector. Does it have continuity? Yes? Great, keep testing...
3b. With the test wire still connected to Wire A in the engine bay, test all the other wires in the DME harness for continuity to wire A. Do any of them have continuity to Wire A? No? Great, keep testing
3c. With the test wire still connected to Wire A in the engine bay, check to see if Wire A has continuity to Ground. No continuity to Ground? Great... Now connect the test wire Wire B in the engine bay and run tests A B and C again.
With this process you will check that each wire has continuity and is not leaking current to any of the other wires in the harness or to ground.
If you only find that 2 or 3 wires are fried and all of the others are fine then without removing the existing harness, run new wires along the same path of the existing harness and splice the new wires into the harness at the DME end and splice them into their connectors/connection points in the engine bay. This is just a temporary fix to get things going. It might work very well.
In any case, I'd start looking now for a DME harness. Make a WTB post in the Pelican 911 parts for sale forum, and start looking on eBay. Maybe give LA Dismantlers a call.
Are you planning an engine out service soon? That would be the ideal time to replace the harness.
Johnr352 04-03-2024 06:26 AM
I'll do this. Thanks very much.
Was hoping not a soon engine out service....famous last words.
nickelplated5s 04-03-2024 08:09 AM
A good voltmeter will check for continuity without the need for a battery. The 'outside' wire is still needed for the continuity check. Better electricians than myself tried to explain using ohms for the same check without the extra wire. Above my pay grade though.
Originally Posted by ErrorMargin (Post 12225201)
My thoughts:
wazzz 04-04-2024 01:59 AM
For continuity, I wouldn't use a voltmeter but an ohmmeter. Preferably with the car battery disconnected. With an ohmmeter you can still use an extra wire to extend one of the ohmmeter leads, as the two of them are too short to test continuity between both ends of the engine harness that runs from engine compartment to driver seat and beyond. Also you should "calibrate" measurements by excluding the extension wire resistance and the probes resistance. They may well add up to 1 ohm. So a continuity test reporting up to 2 ohms from one end of the harness to the other end is presumably a pass.
One way of not using an extension wire for the continuity test with an ohmmeter is to short two of the wires to test at one end and measure/test resistance at the other ends of these two wires. This time you are measuring forward and return circuits, that is twice the resistance that is expected for one wire. Once the two wires test good, you can test them against ground to ensure no leak to ground and against another wire, or another pair of wires, to ensure no leak to these wires.
Sorry for the confusing explanation, English ain't my mother thong. :p
With an ohmmeter, you should always test / take measurements with no external power source interfering with the circuit tested. In automotive, that means disconnect the battery ground or even both terminals.
Johnr352 04-05-2024 04:56 PM
An update. I’m using a continuity tester from Milwaukee. It beeps.
I spent the day preparing to test the different harness sensor leads against the DME connector and Relay connector. As described above. I quickly learned that the O2 heater wire to ground wire short was pretty bad as it’s in the same sheath as the two wires going to the coil. It melted those which caused them to short to each other. Lots of current in those and took the other three wires that go (fortunately) to an unused connection in the rear fuse box. So, I was able to remove and then cut those 8 wires (3 for the O2 sensor, 3 for the unused connection, 2 for the Coil). I stripped the grey sheath back under the car where the bad harness integrated. The wires look ok but now I’ll test the rest of the wires for the sensors. If I’m lucky the wires will be ok and I can have a harness made to replace the O2, Coil, Connector section.http://forums.pelicanparts.com/uploa...1712361648.jpg
ErrorMargin 04-05-2024 05:50 PM
Originally Posted by Johnr352 (Post 12227248)
...I was able to remove and then cut those 8 wires (3 for the O2 sensor, 3 for the unused connection, 2 for the Coil).
That looks bad, can you give us the detail on how this happened?
pmax 04-05-2024 06:41 PM
... I quickly learned that the O2 heater wire to ground wire short was pretty bad as it’s in the same sheath as the two wires going to the coil. It melted those which caused them to short to each other. Lots of current in those and took the other three wires that go (fortunately) to an unused connection in the rear fuse box. So, I was able to remove and then cut those 8 wires (3 for the O2 sensor, 3 for the unused connection, 2 for the Coil). I stripped the grey sheath back under the car where the bad harness integrated. The wires look ok but now I’ll test the rest of the wires for the sensors. If I’m lucky the wires will be ok and I can have a harness made to replace the O2, Coil, Connector section.
Recommend dropping the drivetrain just a tad, don't have to go all the way just a couple inches and a little more would do, so you can access the harness and see it all.
