-   -   Bad idle SOLVED (http://forums.pelicanparts.com/porsche-911-technical-forum/1016673-bad-idle-solved.html)
Artfrombama 12-28-2018 05:15 PM
Bad idle SOLVED
Simple fix but gives me a little confidence in making this car a dependable driver.http://forums.pelicanparts.com/uploa...1546045851.jpg
http://forums.pelicanparts.com/uploa...1546045997.jpg
pmax 12-28-2018 06:29 PM
Yes, the leaking toilet seat "pop off valve"
http://forums.pelicanparts.com/porsche-911-technical-forum/976754-pop-off-not-pop-off-4.html
Congrats !
adias 12-28-2018 07:57 PM
Sorry... what are we looking at above and which engine (SC/3.2)?
Artfrombama 12-28-2018 08:26 PM
Originally Posted by pmax (Post 10298742)
Very informative thread, Thank You. Now I know the POV
was installed backward, the reason that the underside of the air filter element is beat to crap.
And looks like I have a split airbox too, but the engine runs nicely.
Artfrombama 12-28-2018 08:28 PM
2.4
73.5 T
No clue why the photos are turned 90*
Reiver 12-29-2018 07:44 AM
If the underside of your air filter is 'beat to crap' then you have been backfiring.....did the pop off leak prior to the backfires or did they mess your box up.
Hate them or love them....mine, properly installed...has saved my box on two occasions in 3 years now....idles fine, runs great even after those two backfires.
Artfrombama 12-29-2018 10:22 AM
I bought this car as a disassembled project, the injection had been disassembled by a previous owner (R.I.P) that attempted to repair the CIS, never got it running. I bought the car and had the CIS rebuilt (Thanks Brian).
The engine has ran perfectly, no backfires until recently when the fuel pump started to intermittently stop working, then I experienced a couple of backfires and rough running.
The car came with a damaged K&N air filter that I plan to change.
The P.O. didn't throw away the original fuel pump, I tested it on the car and works fine except a fuel leak around the electrical terminals. I've sent it off to the rebuilder in CA. that was recommended on this forum.
I'm sure my airbox is broken, most of the screws are stripped but the engine seems to not mind. Clutch change in the future that I plan to do the airbox and address a few oil leaks.
djpateman 12-30-2018 08:39 AM
The forum software automatically aligns the photos in landscape mode so that the long edge is always horizontal; obviously not an easy thing to change.
manbridge 74 12-30-2018 12:02 PM
Choosing the “square” option before taking a picture solves it.
Bob Kontak 12-30-2018 01:38 PM
I did read in a separate post recently that the early CIS cars cannot be fitted with the newer SC airboxes that have the cold start injector runners.
I don't know anything more about this. Just a heads up.
