7783911's Avatar
switch lighting
what are the correct lamps to use for the defroster and fog light pull witches?..i cant seen to locate them?
Old 03-14-2019, 04:45 PM
Senior Member
Superman's Avatar
We discussed this recently. Do a Search. It depends on what style of switches you have. Tell us what year your car was built. A picture of the switches will help.
Mocha 1978 911SC. "Coco"
Old 03-15-2019, 06:59 AM
7783911's Avatar
i ve seen many posts about led lighting kits, none include the dash switch lights...which I thought were long thin tubes? need pictures or links?
Old 03-15-2019, 07:34 AM
Probably the bulbs are BA7 , but to be sure post a picture of the switches. Different switches for different model year Porsches.
In the Porsche Parts Catalog it reads P/N 900 63 1102 90 Bulb 12V 2W
Old 03-15-2019, 11:37 AM
Recreational User
porschenut's Avatar
I'm impressed with your use of the correct term lamps, instead of bulbs, though sadly I'm unable to help.
Old 03-15-2019, 12:30 PM
7783911's Avatar
its a 77 targa,,,,i will pull apart the switch and check the LAMPS this weekend
Old 03-15-2019, 12:42 PM
You need BA7 bulbs/lamps
Old 03-15-2019, 01:09 PM
Senior Member
Superman's Avatar
For a '77, likely this is true. If so, the lamps are accessed from the BACK of the switch. Here is the recent thread. You may be able to access the lamps by removing the speedometer and reaching through that hole.
Dash Switch Bulb Replacement
Old 03-15-2019, 05:02 PM
Senior Member
Superman's Avatar
In the other thread there is a picture of the defrost switch. It is BROWN. That thingie at the end with the wire attached....is the bulb holder. Pull out the clock and reach behind the switch. Pull the bulb holder straight out. The bulb is the same as your instrument bulbs.
Old 03-17-2019, 09:06 AM
7783911's Avatar
Any idea what the part number is to replace that defroster bulb shown..the one that looks like a golf tee?
Old 03-17-2019, 03:46 PM
