Fuel pump buzz
Should the electric fuel pump on my 3.2 car make a loud buzz when you turn the key to start? Or should the pump be silent? Is loud a sign of possible failure of the pump? Thank you , nick
Hi
My 3.2 fuel pump makes a buzz noise when I turn the key to Start.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
In my 3.0 I didn’t ever recal hearing the Bosch pump run. It failed and I replaced it with the cheap-o Dansk unit from our host. I can hear it run from inside and outside the car but it seems to be working properly.
_______________________________ 1982 911 SC 240,000mi and counting |
The pump in my SC contacts the skid plate under the car which acts as an amplifier. It is loud enough to hear inside and outside the car, but it has been like this for years so it seems like it isn't about to stop working.
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
Nick..there should be no sound from your fuel pump...you should check if you have broken mounting clamp or if it is not hitting the fuel tank protective plate...to start with
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
When your gas tank corrodes the junk clogs the fuel pump and it whines. This has happened twice to me in the 30 plus years I have driven my car. Remove the fuel sender and look inside your tank.
