I am installing B&B Headers on my '93 964 motor this Friday. The gaskets are the crush-type round gaskets that seal the exhaust to the head via a channel in the head. The problem is the gaskets will not stay in the channel while you raise the header to the studs. Are there any tricks to get the gaskets to defy gravity and stay in the channel while you position the exhaust manifold? Has anyone used grease, tape or something else that will burn off to hold up the gasket that will not disrupt the seal?
Thanks in advance.
I think I would go with grease.
Any light grease, or a dab of Super Glue will work
Impotence...Nature's way of saying "No hard feelings." McDaniel 1974 911 Targa 1995 Toyota Avalon 2004 Toyota Tundra Extended Cab |
axle grease, it worked for me.
John Adams 1980 ROW 911SC |
The same anti-sieze you should be using on the studs can hold them up there, more or less.
~Hugh '84 Carrera |
Information Junky
they'll usually hang-up on the studs if the gasket is tipped across the studs.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2˘ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
let me take a stap at this...
what about that high temp copper spray gasket stuff? says it designed for high heat areas like exhaust manifolds? |
Formerly bb80sc
Paul, I used a bit of spray adhesive on the gasket. Works great.....what's that burning smell
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
