Name these pieces please.
I am trying to replace the rubber pieces in the photos below. I assume the rubber rings identified by the red arrows are grommets? I also assume the part identified by the yellow arrow is a rubber wire boot? But putting rubber grommet or wire boot in our hosts search does not give me the part. Any ideas on a name or how to locate in the parts catalogue? If not available here any idea where I can get them?
Thanks in advance for your help.
Old 01-11-2019, 12:03 PM
The PET Catalogue is your friend.
Choose your year, download the PDF and start paging.
Every part number is there.
Google Porsche PET Catalogue 65-69, or 70-73 etc.
Don't buy a Porsche until you can afford two.
1980 SC - sold
1983 SC - sold
2000 C4 - sold
1967 912.5 in DIY build
Old 01-11-2019, 12:27 PM
Thank you.
Old 01-11-2019, 12:33 PM
I'm betting most of those come on the individual wire looms. Get a grommet assortment, split them and slip over the loom.
206 637 4071
Old 01-11-2019, 01:23 PM
It would probably help if you would identify the year of car you are working on, and your photos are a little to close for me to be able to identify the area of the car you are looking at, but good for the part detail. You may consider also posting a wider angle photo in the future to help identify the chassis location. but looking in PET for the 84-86 (what I have) you will find them in various locations, including the fog lite location illustration 905-05 items 20 (Rubber Sleeve 999 702 084 50) and 21 (Rubber Sleeve 911 612 132 00).
Old 01-11-2019, 01:54 PM
Thanks JW, will do.
76FJ55- 74 911. These particular pieces are in the front pan. There are similar in the engine bay and behind the dash. The long pieces ID'd by the yellow arrows go to the fenders/headlights.
Old 01-11-2019, 06:56 PM
Kroon wire harnesses, is the only place I have found that sells large grommets shown with your yellow mark. The other grommets are generic, and can be easily sourced.
Rob
Old 01-11-2019, 07:34 PM
