finally!
Old 03-25-2019, 05:45 PM
scumbag
That is a big picture!
glad you got that balljoint out!
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
IG: @doktor_b
Old 03-26-2019, 03:59 AM
Originally Posted by mikedsilva View Post
Your videos are encouraging.. this is where I am at now...
You saw my picture on page 2 right? I had to cut mine out too. As I'm guessing you found out, once you cut down the nut enough the tension will break and it'll release nice and easy.
If you're ultimately replacing both then it's no harm no foul.
youtube.com/bennyobscene
Old 03-26-2019, 04:49 PM
A friend put me onto this.. use an extender on your torque wrench to get to the 180 ft lbs...
https://www.norbar.com/en-gb/Home/Torque-Wrench-Extension-Calculator
I'm so intrigued by this but can't wrap my physics brain around how extending the lever arm would change how my torque wrench functions. It should be noted that I have the click click type of wrench that breaks at the ratchet end, and not the beep beep type that is likely 100x more accurate.
Old 03-26-2019, 04:53 PM
911 Abuser
Ionizer's Avatar
Extending the handle makes no difference. The extension have to be on the other side of the "break point" to work.
Old 03-26-2019, 05:27 PM
shh-the robot is sleeping
Torque = force x length. Perpendicular to radius blah, blah blah...
Increase length , increase torque.
'88 911 Coupe, 69k miles
Old 03-26-2019, 07:58 PM
scumbag
while you're not wrong, this doesn't apply to torquing beyond the limit of a torque wrench. The wrench can physically keep going, but it won't be able to measure/quantify the torque applied...which happens to be the whole point of using a torque wrench. At that point, you may as well use a breaker bar and turn it until it's GNT.
Similarly, you can keep turning the knob on your stereo forever, but you will reach the limit of what it can output. Continuing to turn the knob does not increase volume past it's limit.
IG: @doktor_b
Old 03-27-2019, 03:50 AM
Registered Minimalist
75 911s's Avatar
But this one goes to eleven...
Duane / IG: @duanewik
Check out my 75 and 77 911S build threads
Old 03-27-2019, 07:30 AM
scumbag
Itís one louder.
IG: @doktor_b
Old 03-27-2019, 07:46 AM
what's a stereo knob?? is that an app?
Old 03-29-2019, 04:25 AM
scumbag
Hol' up, youngblood.
IG: @doktor_b
Old 03-29-2019, 05:08 AM
150 plus or minus!
Old 03-29-2019, 06:32 AM
LOVE these videos Benny! Being a big DIY guy myself but no video editing skills or time. Subd to watch more!
Current Cars: 87 Carrera RS/IROC Tribute, 92 12V Jetta GLI, 07 Ford Explorer, 91 Miata track car
Previous Cars: 00 Carrera, 01 996tt, 07 997tt, APR tuned 12 Beetle
Instagram: @pdklol
Old 03-29-2019, 07:29 AM
Thanks!
Old 03-30-2019, 05:37 AM
Long overdue, but I've finally moved to the rear of the car!
Old 05-02-2019, 04:34 AM
scumbag
Good job!
Can't wait to see the finale and then you clocking some miles.
IG: @doktor_b
Old 05-02-2019, 04:46 AM
doing the thing!
Old 05-29-2019, 08:58 AM
Old 05-30-2019, 06:00 AM
Subscribed! Looking forward to watching!
Old 05-30-2019, 07:44 AM
Looking good man. Nice seeing it back on the road again!
Instagram: @pdklol
Old 05-30-2019, 08:07 AM
Tags
ball joints , bushing , control arm , suspension , youtube
