-   -   Do I received the correct bushing from ER (http://forums.pelicanparts.com/porsche-911-technical-forum/1017897-do-i-received-correct-bushing-er.html)
deftom 01-12-2019 08:51 AM
Hi guys,
I was planning to rebuild my front arms but I found the bushing little bit short.
I would like to havr your opinion.
Base on the bill, I ordered the correct reference for my 911 2.7 1977.
Thanks a lot :)
http://forums.pelicanparts.com/uploa...1547311898.jpg
donagain1 01-12-2019 09:25 AM
I didn't purchase the Elephant rubber bushings, but borrowed their install tools from a fellow pelican and actually pressed on my HD rubber from Uro last night. What you'll find is that the ID of the rubber is so tight (despite the liquid soap on both surfaces) that when you squeeze them on with a pipe or bar clamp as shown in the "How to" video that they will indeed stretch to fill as much of the void as necessary. If you recall from before you removed the old, the rubber didn't come clear out to the end of the sleeve to begin with anyway, and the new one will also come a few millimeters short as well.
deftom 01-12-2019 09:31 AM
Ok thanks a lot :)!
That's what I was thinkibg! But I just want to be sur... I don't want to redo the job twice :)
