Retired Member
Front suspension clunk
I've been chasing a front end clunk for a long time. Always thought it was the brake cooling air ducting kit rattling on the lower control arm.
This morning I was under there and found it. With the car jacked up, the front wheels are just hanging there. As I was going over everything noticed the splined end cap with the front height adjuster is loose on the t-bar. As I wiggled it, it makes the same noise I hear as I go over rough roads. I have the car lowered just a little below euro height. This clunking has been there since I dropped to this height. So - any suggestions to correct? I want to stay at the current ride height. Should the splined end cap be reindexed?? I remember when I installed they would only go in one way. However, the front suspension was hanging. If they are loose on the T-bars, does that mean they are worn out?? The passenger one seems to have a little more movement compared to the driver side. Thanks in advance.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
Under the radar
From your description, I believe you do need to re-index the endcaps on the torsion bars. There should be tension on the adjusting screw, no matter what your ride height is.
BTW, while you are in there you should check to make sure your torsion bars are not rubbing on the inside of the crossbar.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 05-25-2014 at 01:57 PM.. |
Retired Member
Been thinking this through a little.
I do have tension on the "keys" with the car sitting. The problem is as the suspension travels and the car becomes unsprung, the tension on the keys unloads and they become loose and clunk away. This only happens on rough/choppy roads and at higher speeds - likely when the wheel is going through its full travel quickly. If they are reindexed, it will push the car up. Ummmm, no thanks. I'll do some more research on this one. May post another thread with a more specific subject line If others have insight, please chime in. Cheers all.
Under the radar
I have wondered if my torsion caps would twist at full droop. I felt that it was allowing my front end to lift unnecessarily under acceleration.
Here is my attempt at a solution. Notice the nut on the adjusting screw.
Retired Member
Gordon, is this shot at full droop - car jacked up and wheels hanging??
Thanks.
Under the radar
That's with the wheels on the ground. But the nut prevents the torsion caps from moving more than perhaps 1mm when jacked up.
I believe the problem with the torsion cap moving has to do with the fact that we are using larger than stock torsion bars, mine are 22mm. In other words the stiffer torsion bar requires less pre-load, allowing the slack in the adjusting screw. A stock torsion bar would always have tension on the adjusting screw even at full droop? I have wondered if any others have had this problem and needed a solution.
Did this solve the clunk problem?
Dave K |
The reason I ask is that I just when to 21mm tB's on the front and when going over choppy roads I can also hear a clunk.
Dave K |
Under the radar
I didn't have a clunk problem. Since I autocross my car, I wanted to limit the droop on my front suspension. That's why I added the nut. I'm just offering it as a possible solution.
I'm surprised this topic has not come up before.
Retired Member
Thanks.
Retired Member
I should dig out my old tbars to verify. But the question I have, is the splined ends of the front tbars the same or are they offset similar to the rears?
Retired Member
good info in this thread..........
Front ride height adjustment: adjusting screws loose and car stiil too high I will be reindexing the keys. Should be fun.
Under the radar
About 3 1/2 inches from wheels on the ground to full droop when jacked up. Keep in mind that my car is low. Front wheel well is 24" above the ground.
Retired Member
Thanks Gordon. Appreciate your input.
I have a 1500 km tour this coming weekend with a number of prior commitments before we leave on Friday. Not enough time to get into key adjustments before then. I will play with the suspension next week.
Hey Charley
Mine had a clunk when we got back from the Thaw. Turned out to be a loose wheel bearing. Duane
79 SC Daily driver. 3.2ss, twin plug 15 Toyota Tundra. Fox 2.5 DSC Look 695 Ibis Mojo HD Pivot Vault. Cross/comuter/winter bike |
Home of the Whopper
Make sure the nut that holds the strut inside the housing is tight.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
I have the poly bronze and had a clunk and found that the bushing assembly was loose inside the pinch assembly, tightened up the 19 mm bolt and it settled down! Anyone else have this happen.
I'm afraid it may have wallowed out the part that holds it, but for now seems tight |
Found my clunk…….
Battery not strapped down!
Dave K |
Under the radar
Our collective minds solve another mystery.
Retired Member
Fixed. This weekend will be the confirmation.
I was tightening up the front wheel bearings this AM. They were just a little loose. Had the car already jacked up and was looking at the torsion keys. Well, a couple hours later and the keys are reindexed and ride height adjusted. I think the adjusting took twice the time of reindexing. I had the car jacked up with jack stands front and back. Then took my 2 floor jacks and with one under each front suspension, jacked up the suspension to remove the tension on the key. Removed the adjusting bolt, slide out the key and moved it down 1 spline on each side. Adjusting height took a little time. A couple of short drives around the block and fine tuning and she was done. As before, car is about 3/8" lower than Euro height. I like it at this height. However, I do scrape a little more on driveway approaches, etc. Just need to go slow on this stuff. Out on the open road - oh ya baby............ Thanks to the Pelican community and Trackrash's input, it finally clicked for me. As long as it does not clunk............ Cheers.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. Last edited by Charlie V; 05-29-2014 at 09:38 PM.. |
