Working 3-pin CDI in SoCal?
I have a bone stock '71 911E engine that has no spark. I have swapped out the coil, distributor rotor and cap, spark plug wires, ignition points (and also swapped points with Pertronix). Yet I still have no spark. My last two tests are the CDI and the CDI wiring harness.
I should point out that the CDI harness gets about 11.5v at the Red wire with the ignition in the on position as opposed to positive an negative battery terminal being 12.5v.
Does anyone here in SoCal have a known working CDI that they can loan me for testing purposes? I don't want to invest in a CDI Rebuild at Pelican just yet given all of the money I have spent already just getting to this point.
I'm in the San Diego area and wouldn't mind driving up to LA to borrow one if any of you here were willing and could be so generous.
Old 01-09-2019, 06:42 PM
Under the radar
Trackrash's Avatar
I'm guessing that you are not hearing the whine from the CDI unit? Heck, I had to replace, actually get rebuilt, my CDI back in the '80s.
I would recommend taking your car to Black Forest and have them test it.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-09-2019, 07:21 PM
I have one that you can borrow or maybe buy and if you don’t need it I can refund you. Whatever makes sense. Either way I have a working spare
Old 01-09-2019, 08:14 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
you can test the 3-in CDI yourself.
- turn ignition on (must hear whine)
- Connect spare spark plug to output of coil and ground
- close points and there needs to be a spark
Also, ohm out the points and make sure when they close there is GND on the trigger (Pin C of the 3-pin harness connector)
Else you can ship it up here (Santa Barbara) for test and possible fix
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-09-2019, 11:33 PM
Ingo
I have Pertronix instead of points. Can I still do this test, and if so, what do I do different?
Old 01-10-2019, 09:59 AM
Under the radar
Trackrash's Avatar
How I tested my 6 pin CDI.
Gordon
Old 01-10-2019, 10:29 AM
ischmitz's Avatar
The Pwrtonix unit acts as a switch. I would create 4 extension wires (male spade to female spade with 10 inch of 12 gauge insulated wire) and put them between the CDI and the car harness connector.
That will allow you to selectively disconnect the trigger wire (pin C) and touch it to the housing. This should release a spark.
For a little more sophisticated test rig I built a little trigger circuit and a bench setup:
Old 01-10-2019, 11:35 AM
Jonny H's Avatar
What ischmitz said about spare spark plug, then:
Just disconnect the black wire from the Pertronix.
Ignition on. Then ‘drag’/touch spade (on original wire) on engine case. Spark generated when released from case (ground).
www.classicretrofit.com
Old 01-10-2019, 03:30 PM
OK, I did all of this and got no spark when the black wire was released from the ground. Is it reasonable to say that the discharge capacitor has gone bad inside the CDI, hence the need for a rebuild?
Old 01-10-2019, 04:58 PM
ischmitz's Avatar
that sounds like one possible conclusion even though this failure mode is more consistent with 6-pin boxes.
Old 01-10-2019, 07:37 PM
Just want to update this thread by thanking ischmitz for his recommended diagnostic test for my CDI. I did exactly as he said, got no spark, sent it to our hosts for rebuild, and now my no-spark problem is solved. Engine starts up like new.
As per the service report that accompanied my rebuilt CDI, there was a faulty solder joint as well as a failed ZD1 zener diode. Hopefully this info will be useful data for someone else here in the future.
Old 01-18-2019, 05:48 PM
So you didn't consider the one you thanked as a source for CDI rebuilding?
Dave
Old 01-18-2019, 06:04 PM
