Seal around the fuel inlet pipe
Is the seal that seals around the fuel cap and on to the body (where the pipe goes through) still available to buy
******** has them 901.20.159.121
Hmmmmm I guess their censoring us now ??? That's weird
Actually, Pelican has censored certain sites since before I was a member.
Pelican has this part. Sleeve 901 201 591 20, seems it was updated to 901 201 591 21 https://www.pelicanparts.com/catalog/SuperCat/5862/POR_5862_FULFUL_pg3.htm I also replaced this seal when I changed mine. Foam Gasket 911 201 095 00
Ed 1973.5 T Last edited by E Sully; 01-20-2019 at 04:01 PM.. |
I did this job a few years ago it's not fun, not fun at all.
911timesThree
I agree, about as much fun as replacing your fuel hard lines through the tunnel on jack stands with the motor in...
1987 911ST 3.4L G50 LS 20/21 Granite Green Hot Rod 1988 911 3.4L G50 LS 20/21 Guards Red Hot Rod 2020 F87 M2 Comp 6Speed Carbahn 562/567 Gone: 1991 965 Black/Black Turbo Gone: 2002 E46 M3 6Spd CSL style build |
