Front strut Oring
Hello all, I’m having trouble finding the size of the Oring that goes behind the spacer ring on the front strut spindle. The size the parts manual call out I believe is wrong. The diameter parts manual call out is 25.2mm. The diameter of the spindle is 39mm. Hopefully someone has replaced the Oring and knows the correct size. Thanks I should have mentioned my car is a 69E.
That is the part, it just needs to be stretched.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Oring
A 15mm stretch is a lot for a thin Oring! Also what is the purpose for the Oring?
Oring
Bump
Seals against water getting into the wheel bearings. Sent from my iPhone using Tapatalk
‘84 Carrera, heavily modded Please follow me @chopped_up_fitness |
Maybe there isn't a thin enough oring at ~39mm, so they speced a smaller to be stretched.
But it is the right part and its there to keep moisture from getting in there.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
