LinkBack | Thread Tools | Rate Thread |
JED
Master cylinder replacement/ PO welded master to pedal cluster ARRRRR
PIA
![]() Last edited by ARCSinAK; 01-23-2019 at 06:23 PM.. |
Holy smokes....
What about a Dremel “multi tool” to cut that bugger out of there (a little more surgical than a “saws all”).
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
JED
Upon further inspection believe its just heavily corroded and there a seam in the cluster.
Been leaking a long time. Searched the forums on master cylinder replacement seem the hardest part is re-seating the supply lines into the two rubber seals on on top on the MC. Got the new/used fuel sender in today!! Nice to have a fuel gauge when your odometer is not functioning. Received a new Ignitor Electronic Ignition Module going to try that in a spare 76 dizzy as the 74 is running on points and a condenser no CDI. She's a project. ![]() |
