Hand brake contact riveting
I am repairing the handbrake contact on ‘69 911. Looking for tips on installing the rivets that hold the contact. Reference items 8,9 and 10 parts. Space is very tight with the pivot bushing in the way.
How have others installed these Copper rivets? Thanks! David Last edited by David757; 01-05-2020 at 01:32 PM.. |
Caveman Hammer Mechanic
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Access the issue with this repair. General riveting resource is not the answer. Will post picture
A different handle should be easy to find.
Image added
another photo
my advice is that if you have it all out, may as well do your heater cables and possible e-brake cables...
I’ll probably just make a mandrel to drive the rivets in.
Use a pop rivet or a cherrymax of the proper dimension.
Bucking bar and rivet driver
I made a bucking bar and rivet driver to match the shape of the rivet head.
Worked well. ![]()
Nice!
