Seine System Mod
Looking for feedback on the gate shifter modification offered by Steine Systems.
Like/dislike
82 SC Twin Plug 3.2 SS ,46 PMO
Old 01-25-2019, 12:59 PM
like very much
80SC (ex California) 3.2SS
Old 01-25-2019, 01:02 PM
It's the most reasonably priced gate shift type unit available. I've used one for years and couldn't be more pleased!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 01-25-2019, 01:24 PM
kwikt 911's Avatar
Great for the price!
Old 01-25-2019, 01:26 PM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
A worth while improvement. I am very happy with the way my car shifts. If you don't have the FACTORY short shift, that should also be on your list.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-25-2019, 02:32 PM
I do have factory short shift do you recommend both
Old 01-25-2019, 02:53 PM
Under the radar
Trackrash's Avatar
Definitely.
Gordon
Old 01-25-2019, 03:00 PM
wareaglescott's Avatar
another positive vote for the seine
Old 01-25-2019, 04:12 PM
The addition of the Seine gate shifter plus a FACTORY short shifter
has been the most impressive improvement I have ever made
to the driveability of my 911. PERIOD!
I also added the Coupler Whisperer shift coupler bushings which unfortunately are no longer available.
Old 01-25-2019, 04:32 PM
jmz jmz is offline
jmz's Avatar
I have 2 Wevo kits and 1 Seine/short shift kit.
I like them all. It is hard to say which is better because each box is different but the Seine kit is worth the money and effort.
I'm going to try a JWest shifter on my current project because the look will fit better with the '68 and its 915 retrofit gearbox.
...I sound like some sort of shifter slut.
Jay
'74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'80 911SC Weissach 3.2 Short Stroke Hot Rod
'68 SWB 911T build in progress -The Rat
Old 01-25-2019, 05:13 PM
A great shift kit for the money. Used in my 82 SC.
It is recommended to cut your rubber shift boot to allow the side bolt to stick out. My boot has held up well without being cut and I like the stealth mode.
Old 01-25-2019, 08:47 PM
4flyboy's Avatar
Seine V JWest
I bought a used 915 shifter with a properly welded (tabs) Seine kit installed 5 years ago. Installed it, adjusted it, absolutely love it.
3 years ago I purchased the JWest shifter, it's still on the shelf.
I've been restoring the car a bit at a time. The JWest piece is a low priority simply because the Seine works so well.
I'm really interested in the difference between the two. Here in April when my mechanic gets home from the middle East we have plans to go through the entire suspension and I'll install it then.
I'll decide then which to keep.
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 01-26-2019, 06:10 AM
devalued member
juanbenae's Avatar
Location: Mumbai West, Silicon Valley Ca but headed to the foothills soon
ive had them on two cars and they are great.
75S slick-lid webered, early n spicy 3.oL hotrod wanna be
07.5 2500HD Duramax 4x/93 tuff-gong 4.oL YJ Wrangler
08 DRZ400SM+FCR Mikuni/78SC PRC Spec911(sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ
Old 01-26-2019, 08:20 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
2 911s, both used the system, great product, at a reasonable price!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-26-2019, 10:02 AM
Thanks all I am sold
Old 01-26-2019, 12:18 PM
Was reading on reviews in Pelican, seems like most mentioned that the pivot pin with the Seine kit is to large and has to be machined down or Oem hole in shifter needs to be drilled out. Has Seine corrected
Old 01-26-2019, 01:40 PM
Not a problem, I think perhaps you misunderstood what they were referring to.
The fact is that the shift housing itself has to have the oval opening on the right side enlarged to accommodate the longer pivot pin that comes with the kit. The install instructions will make it all clear to you. Don't sweat it, just buy one and do it. LOL
Old 01-26-2019, 02:27 PM
devalued member
juanbenae's Avatar
there is some work involved. the shifter housing "cutout" has to be elongated. I used a barrel shaped grinding stone that I inserted into a drill press. the housing is soft being aluminum so removing material is not too tough to do. I suppose a drimmel with a stone or one of those barrel type sander attachments would serve your purpose.
if you don't weld use the hose clamp to secure the gate selector to test it all after reinstall, then take it to a welding shop with the hose clamp still attached and tell them you want it there... if I recall one member simply JB welded it to the shifter shaft
Old 01-26-2019, 02:30 PM
Walt Fricke's Avatar
Don't forget to replace the stock oval bushings in the shift coupler under the plate in the rear of the center tunnel with tight round bushings. This takes a lot of the slop out of the system, and bushings are a lot cheaper than fancy couplers.
The most clever way to do this that I have seen is to find, in a good hardware store, some brass bushings which are a tight fit on the stock coupler cross pin. Then you drill out the oval stock bushings (your old ones will do if they are still in one piece) so these bushings can be pressed in. Voila.
Old 01-26-2019, 07:08 PM
Banned for Life
RSBob's Avatar
Had one in my 73 and one in my 82 and love the direct engagement. No misgivings.
Have a Rennshift in the 914 and it too is a quality unit. Seine doesn’t make one for 914-6s with a side shift.
Rick S, '71 914 3.0, '82 911SC EFI, R Gruppe #309
FOR SALE: 968 Cab, Tip, silver blue, new paint, top, seats, shocks, struts, needs nothing. PM if interested
Old 01-26-2019, 08:17 PM
