Accessory wiring help
I’ll be installing a gps tracker in my 87 930 which requires one of the leads to be connected to a power source when ignition is switched on. It also requires constant power and a ground. I’d like to have it in a relatively discrete location. The unit is about the size of a deck of cards. The leads on the unit are 6-10” long.
Can I get a recommendation on where the best sources for constant, ignition and ground hook ups might be?
Thanks!
Old 01-18-2019, 04:58 AM
Been here a while
tell us a little more about your car (year). Often the fuse panel has some accessories that are not part of your car, such as power windows or sunroof on the earlier cars. So, it's very easy to slide the wire in there. Similarly, the trunk offers many discrete locations, such as inside the smuggler's box or near the gauges or blower motor.
looking for 1972 911t motor XR584, S/N 6121622
Old 01-18-2019, 05:49 AM
another option
the 3 wires you are looking for will be behind your radio
and you can probably velco the tracker above the glove box
1981 930 euro
SOLD 1980 911 targa euro
Old 01-18-2019, 06:04 AM
It’s a standard issue ‘87 930 with AC, sunroof and cantankerous 4 speed. I removed the radio but wires should sill be there. Would there be an “always on” hot feed there?
Old 01-18-2019, 12:59 PM
Been here a while
Yes, your 87 factory wiring would have constant power, switched power and ground at the radio location.
Old 01-18-2019, 01:42 PM
TerrIfic and many thanks!
Old 01-18-2019, 01:44 PM
famoroso's Avatar
Source a $7 Scosche wiring harness (used to wire aftermarket head units without cutting the original harness) and use that to wire your GPS in-line without hacking your OE wiring.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 01-20-2019, 08:31 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest
Behind the passenger's floorboard you can find an after ignition +, a constant + and a ground wire. Lots of space and not to be seen.
Kees.
Old 01-20-2019, 01:51 PM
Thanks everyone. I got behind the radio area and found a 6 pin connector with the green wire switched power. I could not get a constant power but need to check fuses:
I also found these four connectors and hoping they are leads to speakers from a long gone radio. Any confirmation is helpful:
Sent from my iPhone using Tapatalk Pro
1987 Marine Blue 930
1982 911SC
White Plains, NY
Old 01-21-2019, 10:52 AM
Been here a while
Yup, those 4 connectors are for speakers
On the 6 pin connector, brown should be ground and red should be constant
Old 01-21-2019, 11:22 AM
Thanks Blucille. So I should see 12v when I probe red and brown with key out of ignition?
Old 01-21-2019, 11:24 AM
Got it sorted. I found a harness that plugs into factory radio harness through Crutchfield. The constant power wire was dead due to bad fuse. Swapped a fuse in and voila, all worked. Thanks for the info and thoughts.
1982 911SC
White Plains, NY
Old 01-28-2019, 07:46 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Yes do tell us a little more about your car, accessories, wheels etc. When are you home, alarm on the garage, wife, dogs ect. Please be more specific as to location of gps tracker.
Your friendly car buddies....
Just kidding.........
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-29-2019, 09:12 PM
