Cold weather Autocross Tires
Here in the Northeast the season for racing starts and ends with sub 45 degree temperatures. Any recommendations as to type and brand of tires. I have Bridgestone re1ís and the spec sheets say not to be used in these conditions. I race a 1979 911 SC.
I drive to the events if under 1 hour away. It is not used for much else.
Thanks for your input. I posted here and not the Autocross/ Race section because of the number of people that are on this forum.
Old 01-28-2019, 06:21 AM
cycling has-been
bkreigsr's Avatar
All track-related tires are going to say that, as it holds true across the board.
FWIW - I drive my Proxy ES - R-888 year-round, and they hold surprisingly well on cold blacktop -as long as I don't do anything stupid.
Bill K
Old 01-28-2019, 08:10 AM
Rescuer of old cars
Arne2's Avatar
One of our local club members runs Michelin Pilot Sport A/S 3+ in March and April auto-x events, and Toyos of some sort later in the season. He says the Michelins do really well when it is cold and/or wet.
"Honestly now, did you spend your youth dreaming of someday owning a Nissan or Mitsubishi?" - Porsche ad from early '90s
1972 911T coupe
Priors - '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-28-2019, 08:15 AM
i never noticed much or any difference in how the A/S grip hot or cold and wet. They were flawless regardless of conditions. Can't say the same for the S-02s which are like bakelite when cold&wet
80SC (ex California) 3.2SS
Old 01-28-2019, 08:35 AM
racer's Avatar
depending on the actual conditions (sun light, surface etc) just cause its below 45 degrees when you leave home, doesn't mean the surface wont be above 45 by the time you run your heat. fwiw, I've been stuck on R comps in snow/slush at the track.. and drove home on the streets etc.. so the tires should be ok, but simply "not recommended".
I'm not sure its worth the hassle to try to find some "magic" tire for the scenario you post. How many events does this impact? 1-2? 10? What are your competitors running at those same events?
What size wheels are you running on your SC? some brands might not offer the sizes you might want to try anyway.
Past:
2000 Boxster 2.7, 1987 944
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 01-28-2019, 09:07 AM
