ahead of the curve
original miles?
going through a box of old porsche parts I found this modded part - based on how rusty the part is I suspect it was a targa and the claimed miles were not quite accurate
19 Carrera T - MPS member 92 C2 SR coupe M491/ 3.8 look- manual 92 C2 SR coupe cobolt blue- manual 73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy 73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
New-ish 911SC Targa Owner
ah, so you suspect the turned off the speedo signal with that rocker switch which would render the odometer static? how very slick!
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
I'd say that the only certainty that exists with any G body odometer is that the figure represents the absolute minimum number of miles on the chassis, inline switches notwithstanding. I wonder what the percentage of truly accurate readings is. Can't be very high.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
The 9 Store
Speedo's are so easy to switch on many cars built before Y2K. To me, condition is way more important than milage. I have a 40K mile east coast 914 that is in much rougher shape than my ~140K mile car that came from the west coast.
All used parts sold as is. |
I have an 83 targa that shows 70k indicated. However, carfax shows that it failed California smog back in the 1990's with 290k on it so...
Fair point. Odometer failure is near 100% I've heard.
Who cares. At this point these cars are all 20-30-40-50+ years old. Condition is everything, indicated milage is basically nothing.
If you told me I had to drive across the country tomorrow and my choices were between an old 911 with 3,000mi or one with 300,000. I’d take the later every time.
_______________________________ 1982 911 SC 240,000mi and counting |
as Quew..said it does not matter..when i got mine it had over 300K and that was one of the reason i go it..now it has as you can see below a little more.....
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
