Help with oil cooler piping
I was hoping someone could help me by pointing out which oil pipe needs to be routed through the thermostat and cooler, is it 3 or 4 ?
[IMG][/IMG]
Thanks for you help.
Old 01-31-2019, 02:56 PM
#4 clearly goes to the engine mounted cooler
_______________________________
1982 911 SC 240,000mi and counting
Old 01-31-2019, 03:02 PM
Just to clarify , I'm fitting a fender mounted cooler
Old 01-31-2019, 03:05 PM
Then it isn’t pictured. What year car and what engine?
Old 01-31-2019, 05:56 PM
The picture is the standard layout for a 1970 T , I am adding an aftermarket front fender cooler running back to a Mocal thermostat and need to know were to plumb it in.
Old 01-31-2019, 07:21 PM
#3 from the engine and through the cooler then back to the tank.
Old 01-31-2019, 08:15 PM
RETIRED
Joe Bob's Avatar
Contact Elephant Racing. They have a diagram and all the parts to plumb a front fender oil cooler.
You can start here. Chuck will also answer the phone and give direction.
https://www.google.com/search?q=elephant+racing+oil+cooler+diagrams&rlz=1C1VFKB_enUS735US735&tbm=isch&source=iu&ictx=1&fir=lR6xg1RyVdckOM%253A%252CcLcDm9CGynpo0M%252C_&usg=AI4_-kRBMNy3K6jVmCrigcjYuk_L19KWcw&sa=X&ved=2ahUKEwjWrbvj4pngAhUK_4MKHfrLAp0Q9QEwB3oECAMQE g#imgrc=_
2012 ML350 3.0 Turbo Diesel
Old 01-31-2019, 09:08 PM
Thank you , that's what I needed to know.
I plan to cut the pipe and add 12AN pipe fittings to the ends to match the thermostat.
I'm afraid the Elephant stuff is way beyond budget
Old 02-01-2019, 03:59 PM
