Rennline Radio and Hvac delete plates installed
Here are some pics of my original radio and hvac delete. I used one plastic plate for the radio and a a second plastic plate glued to the Hvac facia. It was not perfect, but look pretty decent. It was a pain to keep alingning them all the time since the radio plate had a lot of play.
![]() ![]() The Rennline parts were as expected, excelent fit and finish and gives the area a clean look. (See attached pics) ![]() ![]()
79 SC Back to Basics! 2006 997 C2s Cabrio - Sold 1999 996 C2 - Sold |
Perpetual Reassembler
They look nice installed.
Do those have some locating feature on the back side that fits into the radio hole or are they literally $45 laser cut pieces of flat textured plastic?
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer |
I've had mine installed for probably 7 or 8 years. Nicely cut pieces of metal that are contoured to fit into the dash recess perfectly. They have studs on the back, held in place with 2 slips each panel, with nuts onto the studs.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
And for the other member, the have locating bolts and are made of aluminum like most of Rennline’s products, if I recall correctly.
Ass-engine Nazi slot car -- PJ O'Rourke |
I bought their 964 pieces which worked perfectly. Don’t know why they waited so long to list as SC/ Carrera too.
Hi, they are secured in place with 2" tabs and nylon lock nuts.
Very nice! I may have to swap out the Porsche one for rennline radio plate as well!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Very cool. Thanks everyone for confirming the fitment/retaining methods.
Registered Minimalist
45 dollars. Dang. I might trim my 18$ Porsche plate and call it good.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
