911sc power window question
I have a 78 911sc, and I put the drivers side window down to store it in my shop with the cover on. Now the window just clicks when I try to put it up. I tapped pretty hard on the motor to see if that would help, but it won't move. Did my motor go bad, or is there something else I should be looking at? Thank you for your help in advance.
zuk |
Swap the switches, see if it changes the behavior.
Now I'm not sure I even have the switches installed correctly. Does anyone have a wiring diagram for a 78sc? I keep blowing fuses, and found a diagram on pelican but it doesn't seem to work on my car. This is driving me nuts and I have to have the car out of the place it's stored tonight. Thanks everyone.
zuk |
Correct schematics are in here:
https://www.dropbox.com/sh/hr6dquonkwjp23a/AABjbboPo-4J2L9nBoC5tbh6a?dl=0 |
@emcon5
That was very helpful thank you. |
