Porsche 2,8l piston ring set
Hi,
I am new in this forum and also new in Porsche world. Please help me to find right piston ring set for Porsche 2,8. Cylinders are Mahle Nikasil 92mm. The old rings are 1,5-1,5-4mm. I am searching from two weeks and can’t find proper set. On old ring is written goe5. I thing it’s a Goetze, but which exactly I don't know. I will be grateful for any help. Thanks |
Did you try EBS racing?
Yes, they have only standard 90mm.
I would rather be driving
Total seal can custom make rings for you. You will need the cylinder bore (actual dimensions) measurements to get accurate ring gap. Reasonably priced and turn around time.
I had some made years ago for Mahle 98mm RSR pistons. They also had 1.5mm top/middle ring.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Thank you very much for advice. I will send inquiry. Hope to find solution.
Total seal has a massive list of existing rings they can set you up with. I'm sure they have something that will work
No physical quantity completely explains its own existence |
