Porsche 2,8l piston ring set
Hi,
I am new in this forum and also new in Porsche world. Please help me to find right piston ring set for Porsche 2,8. Cylinders are Mahle Nikasil 92mm. The old rings are 1,5-1,5-4mm. I am searching from two weeks and can’t find proper set. On old ring is written goe5. I thing it’s a Goetze, but which exactly I don't know. I will be grateful for any help.
Old 01-31-2019, 11:19 AM
Did you try EBS racing?
206 637 4071
Old 01-31-2019, 11:56 AM
Yes, they have only standard 90mm.
Old 01-31-2019, 12:25 PM
I would rather be driving
jpnovak's Avatar
Total seal can custom make rings for you. You will need the cylinder bore (actual dimensions) measurements to get accurate ring gap. Reasonably priced and turn around time.
I had some made years ago for Mahle 98mm RSR pistons. They also had 1.5mm top/middle ring.
Old 01-31-2019, 04:54 PM
Thank you very much for advice. I will send inquiry. Hope to find solution.
Old 02-01-2019, 12:28 AM
Total seal has a massive list of existing rings they can set you up with. I'm sure they have something that will work
No physical quantity completely explains its own existence
Old 02-01-2019, 03:37 AM
