Euro specs 1985
I just always assumed that Euro cars had the higher compression engines. I was surprised when my 85 cab did not. Does this mean that cabs even though row, did not get the higher compression engines or am I reading chart below incorrectly (my vin is highlighted).
930/20 170kw 930/21 150kw this motor was also used in US & J
Are the hp figures rear wheel or fly wheel numbers?
This chart implies that no Cabriolets were 170kw. Is this correct?
abides.
That chart is incomplete/inaccurate. Look at the back of the '86 PET catalog for a better list of '84-'86 engines.
Code:
911 CARRERA COUPE 85 F 91FS1 00001>05000 930.20 170 KW 911 CARRERA TARGA 85 F 91FS1 40001>45000 930.20 170 KW 911 CARRERA CABRIO 85 F 91FS1 50001>55000 930.20 170 KW 911 CARRERA COUPE M298 85 F 91FS1 00001>05000 930.21 152 KW 911 CARRERA TARGA M298 85 F 91FS1 40001>45000 930.21 152 KW 911 CARRERA CABRIO M298 85 F 91FS1 50001>55000 930.21 152 KW 911 CARRERA COUPE (AUS)(S)(CH) 85 F 91FS1 00001>05000 930.26 170 KW 911 CARRERA TARGA (AUS)(S)(CH) 85 F 91FS1 40001>45000 930.26 170 KW 911 CARRERA CABRIO (AUS)(S) (CH) 85 F 91FS1 50001>55000 930.26 170 KW 911 CARRERA COUPE (J) 85 F 91FS1 09501>09999 930.21 152 KW 911 CARRERA TARGA (J) 85 F 91FS1 49501>49999 930.21 152 KW 911 CARRERA CABRIO (J) 85 F 91FS1 59501>59999 930.21 152 KW 911 CARRERA COUPE (USA)(CDN) 85 F 91FS1 20001>25000 930.21 152 KW 911 CARRERA TARGA (USA)(CDN) 85 F 91FS1 60001>65000 930.21 152 KW 911 CARRERA CABRIO (USA)(CDN) 85 F 91FS1 70001>75000 930.21 152 KW 911 TURBO COUPE 85 F 93FS0 00001>02000 930.66 221 KW 911 TURBO COUPE (CDN) 85 F 93FS0 50001>52000 930.66 221 KW
Graham 1984 Carrera Targa |
Thanks, actually I did a little more research and it seems that I might have an option M298 car which comes with the 930/21 engine and catalytic converter and therefore lower power.
