Bumperette delete how to cover nuts holding on bumper
I've read a lot of the bumperette delete threads and seen a lot of amazing results. How are you guys getting rid of the nuts and washers that hold on the original bumper? Has anyone found an inexpensive and simple way of covering them or doing something that looks more presentable? I don't want to spend the money to have this all professionally done and would like to keep my car so it can easily be returned to its original look. thanks!
Old 02-05-2019, 01:59 PM
Leave the rubber strips? I think it looks better, it ties in the front of the car with the rubber strip on the front bumper and softens the lines from accordions.
_______________________________
1982 911 SC 240,000mi and counting
Old 02-05-2019, 02:03 PM
Old 02-05-2019, 02:14 PM
Old 02-05-2019, 02:28 PM
Thanks guys but I want to ditch the rubber strips also.
Old 02-05-2019, 03:15 PM
I'm good with tools.
AG81's Avatar
If you have a great paint match and use an exact size plastic plug the finished look is quite good.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 02-05-2019, 03:25 PM
Bumper plugs in Charlotte NC, they match paint to your spec had to use small finder washer on back. They look pretty good paint match perfect
82 SC Twin Plug 3.2 SS ,46 PMO
Old 02-05-2019, 03:36 PM
I believe the OP is talking about these. I have no idea how to delete them but I’ve seen pictures of cars with bare bumpers. I don’t know if they were modified originals or fiberglass reproductions.
To plug the holes from the bumperetts I just found some vinyl plugs at the hardware store and used a silver paint pen. About as low cost and low tech as you can get, it looks a little trashy but that fits with the overall astetic of my 911.
Old 02-05-2019, 04:22 PM
I welded all holes ground smooth. Welded 1/2 aluminum bolts to back side of bumper. Enlarged holes in bumper shocks and bolted them on. Totally slick. No plugs pillows or anything.
Old 02-05-2019, 04:27 PM
Bingo QueWhy! Thanks for adding the red arrows. I can deal with the holes but the nuts and washers look pretty hideous.
Old 02-05-2019, 05:33 PM
CC, would like to see or hear more details. The part I’m not getting is how to change screws coming out of bumper shocks or in my case crush tubes I ordered but haven’t received yet. I’m no fabricator so am looking for a procedure.
Old 02-05-2019, 05:43 PM
Mike80911's Avatar
Maybe a cheaper and easier way would be to use carriage bolts and either leave them as is or paint the heads to match the body
89 930 Cab Black
11 Cayenne
Old 02-05-2019, 05:57 PM
or go FG and save some weight while yer at it?...
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 02-05-2019, 06:02 PM
My other ride is a C-130J
RNajarian's Avatar
Santa used a little bondo to cover up the holes
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 02-05-2019, 10:51 PM
Bill Douglas's Avatar
My thoughts too. An uncomplicated way of doing it.
Old 02-05-2019, 10:58 PM
Registered Minimalist
75 911s's Avatar
Two easy steps:
Step one, grab about 500 space bucks.
Step two, hang your stock bumper up in the garage and begin work on the used bumper you picked up...
Tig weld up some 18 odd holes. *I left one for the tow hook stock mount
Buy euro crush tubes (this is a lightening project after all.)
Cut the studs off yer brand new crush tubes
and drill holes. The tubes must also be sectioned 3/4" to account for reverse mount bracket depth on inside of bumper. You can then use large washers (spacers) at the chassis and body mount location to adjust depth of the bumper.
Aluminum stock. Slotted with carriage bolts
Using my muffler guy's press brake I folded the edges of the aluminum bracket down to allow the carriage bolts to slide back and forth. The folded edges are reinforced and then the bracket is tig welded into the right spots.
I ran a brushed look for a while. I loved it! I have now painted the bumper (boring!)
Get out and drive
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-06-2019, 04:42 AM
AG81's Avatar
I have got to get this on my Christmas play list.............
02 996 4S
Old 02-06-2019, 05:08 AM
Duane,
Thanks a bunch! That is exactly what I was looking for.
Derek
Old 02-06-2019, 11:39 AM
75 911s's Avatar
Originally Posted by Derek77 View Post
Duane,
Derek
Anytime. I like this solution better than bolting on a plastic bumper.
Here's a shot of the sectioned euro crush tubes that wouldn't fit in the previous post.
Big washers to space the impact tube / bumper out evenly:
Tow hook hole:
I sanded the bejeesus outta it and then did a brushed aluminum look and then clear coated with high temp.
Here it is painted:
Old 02-06-2019, 12:02 PM
I used a donor bumper and steps similar to Duanes, used JB Weld to fill the holes and fabricated crush tubes, wrapped it in matte black vinyl.
Wrapped the front bumper, rockers and added stripes.
Old 02-06-2019, 12:48 PM
