Almost Done
sun visor fix needed
My visors (77 Targa) arent droopy and appear in good shape..but they seem "loose" and dont stay in the closed position well...what can I do to "tighten" them up?
thanks
Old 02-08-2019, 07:49 PM
Banned but not out, yet..
RSBob's Avatar
There should be a screw in the visor near where the fixed end right angles into the windshield frame. Tighten that up
82SC Made of matter, but not that much
Old 02-08-2019, 08:02 PM
Almost Done
No Screw found in the visor, only in the mounting plates, looks like its just the prong that goes into the visor. I wonder if I could shift the mounts a bit to get a "tighter" fit..otherwise pull apart and add some dimension to the prong itself or inside the visor hole
any other ideas out there?
Old 03-26-2019, 04:43 PM
Heck I'm only 5 not 66!
targa80's Avatar
Below is thread on my refurbishing of my 80SC passengers side visor and it has the tension screw. Your only option without the screw would be to add a screw to the mounting bracket that could add tension to the bar or add thickness to the bar going into the mounting bracket.
80SC Targa Sun Visors Refurb (on the cheap)
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 03-27-2019, 04:45 AM
