"Rebuilding" red trumpet horn?
In putting my '72 targa back together one of the horns doesn't work- looks fine, took it apart but couldn't see anything obvious. Can they be rebuilt or any tricks?
1971 914- original owner
1973 914 2.0
2018 911 carrera T
2016 981 Spyder PTS
Old 02-10-2019, 09:48 AM
I've been corrected- this is a banjo horn- don't know how to edit the thread title!
1973 914 2.0
2018 911 carrera T
2016 981 Spyder PTS
Old 02-10-2019, 01:25 PM
I just cleaned up and "tuned" a set of trumpet horns. Not sure if the banjos are the same, but their is a screw on the back of the diaphragm that tunes the sound. With power applied back the screw out till it stops honking, then turn it in till you get the tone you want.
Edit, I have no idea if this is a correct procedure, but worked for me.
1978 SC Targa
Old 02-10-2019, 03:43 PM
I did the same about 19 years ago. One horn did not work and the other was just weak. Cleaned them up and adjusted the screw with 12vdc bench power. That was it.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 02-10-2019, 06:15 PM
