Exhaust Vibrations
My 911 3.2 has an exhaust rattle when the engine is hot. The rattle is only noticeable when slowing down and when there is no load (feet off the accelerator).
I think it is the muffler, is there any isolation material I can use between the muffler straps and the engine mount cross member ?
Sound like a metal on metal vibration.
Any ideas ?
Old 02-12-2019, 11:15 PM
Bill Douglas's Avatar
Have you had a look under there?
Old 02-13-2019, 12:20 AM
Yes! If you still are running the factory exhaust setup with the cat, look for a loose heat shield.
Old 02-13-2019, 12:38 AM
Muffer Vibration
It's an aftermarket exhaust
Will take to my local exhaust shop for a closer inspection
Old 02-13-2019, 01:32 AM
a.k.a. G-man
Geronimo '74's Avatar
loose internal baffle?
Old 02-13-2019, 02:17 AM
