 Can anyone identify this turbo? I was wondering if anyone could identify this turbo in the photo below? The intake housing looks much larger then the exhaust side. Thoughts… guesses?  http://forums.pelicanparts.com/uploads/turbot.jpg |
 Hmm...compressor-housing looks like plain vanilla KKK K27 or 3DLZ, turbine-housing might be little smaller (K-26 hybrid?) but to me it looks pretty stock. Can you post numbers off the turbo? |
 Hard to tell from this angle. Looks like K-27 compressor, the hot housing looks like a K-23 from a TT. With the size diff. could also be a K-29 compressor with a K-26 hot housing. Both would be Hybrids. What's it on? |
 The turbo is on a 930 that has been highly modified. The engine has been punched out to 3.5 liters, twin-plugged, GHL heat exchangers, etc. Does the K-27 compressor housing have the multiple ribs on the top compressor port (see photo)? Every K-27 I've come across only has a single rib/lip on top. What would be the advantage of a hybrid turbo? |
 I've seen them both ways, you can get adaptors to match the neck with porsche down pipe. K-28, K-28s, K-30, are all hybrids. The turbo builders mix the compressors and hot housings to get more boost, or quicker spool up. I run a K-30 on my car. |
| All times are GMT -8. The time now is 01:09 AM. |
