Just got my lift
I just got my garage lift in and can't weight to change the oil just so I can use it! It is not the best but it will do the job. Finally, I won't have jack up the front, then the back, and then get the stands, and go through the whole process backwards to take it down.
Old 03-14-2003, 10:10 PM
Don Plumley's Avatar
Looks great - details!
Don Plumley
M235i
Old 03-14-2003, 10:13 PM
Senior Member
Doug Zielke's Avatar
Looks pretty rugged.
Just don't crush your oil lines!
(I see the Sawzall is ready if you do.)
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Yea, I definitely will be sure to not crush the oil lines. It is pretty rugged. Considering it was less than $1000, it looks pretty durable and even if I have a problem with the motor/pump, it can usually be purchased at a reasonable price. Considering I won't be using everyday it should last.
Old 03-14-2003, 10:18 PM
Where did you get it and what powers the hydraulics?
Don Plumley
M235i
Old 03-14-2003, 10:24 PM
I got it from harbor freight. Check out www.harborfreight.com and look up item number 46604. It is powered by a 1 hp, 110V motor. The motor is attached to a dolly that also allows you to move the lift around if you need to. The motor is actaully mounted to the dolly and there are hydraulic lines that connect to the lift from the motor. Assembly was pretty easy.
Old 03-14-2003, 10:29 PM
jbripps's Avatar
Great lift!!
I've been researching them too. I would like to get one to store my car in the winter (and do some work too!), so I'll need a 4 post lift, mainly looking at Eagle.
Best of luck and have fun!!
regards,
Jon
'85 Targa (recently acquired by Coollx)
'02 Carrera 4S (holy moly...I'm in heaven....in the snow too)
'06 BMW 325i (gone and forgotten)
'03 Honda Odyssey (more dings every day....thanks wifey)
Old 03-15-2003, 04:38 AM
Is there a device to lock it in place once it is fully extended?
1991 C2 Cabriolet Tip, 1994 Speedster
Old 03-15-2003, 04:55 AM
marcesq's Avatar
That's a dam good question. Code ???
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 03-15-2003, 05:22 AM
If it can't be locked into position, I bet a few well placed jackstands would do the trick.
Old 03-15-2003, 05:43 AM
Ray 911s's Avatar
Wow - great price. I'll look into it; thanks for the link to HF.
Have you driven over it yet? I'm wondering about clearance issues as I would have to store it under the 911.
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 03-15-2003, 05:44 AM
one of gods prototypes
bell's Avatar
harbor freight rocks...........they have a retail store close to me, you can usually find 6 ton jack stands for less than $20 there.
a freind has that same lift at his shop, it works great and is very stable as i've used it a couple of times
good find
Brought to you by Carl's Jr.
Old 03-15-2003, 06:14 AM
makaio's Avatar
I gotta have one!
Old 03-15-2003, 06:43 AM
Cool
I'm sure it's a good one.. the Snap-On mid rise lift is the cats a$$.. sells new for big bucks.. but used can go for $1,000.. I posted pics here before of it.. do a search or I'll post the pic again.. and the Snap-on can be driven over w/euro ride height, or you gotta use a board to drive on for clearance........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-15-2003, 07:05 AM
Cool
all lifts have some kind of safety specs to comfirm to.. like a minimum of 6,000 lbs.. my mid-rise lift has a lock in max up
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-15-2003, 07:08 AM
Mrdi's Avatar
Do the feet scrape up the floor whan the jack goes up with the weight of the car on-board?
Mrdi
88 Carrera G50
Old 03-15-2003, 07:12 AM
Mrdi's Avatar
How high does the car go up, and can you drive right over it?
This is a very intriguing item
Thanks for the post
Mrdi
88 Carrera G50
Old 03-15-2003, 07:14 AM
Cool
I use a 1/8 inch steel plate.. usually sold in 4X8 sheets.. this not only smooothes out the rollers travel, but will help prevent all the concentrated weight from cracking the cement......... Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-15-2003, 07:19 AM
Mrdi's Avatar
Raise cars or trucks 39'' to work on brakes, mufflers or wiring. Steel plate construction. Includes lift, electro-hydraulic pump, dolly, four saddle pads, and one gallon of hydraulic fluid.
Motor: 220 volts, 1 HP, 3450 RPM, 6-8 amps (under load)
Weight capacity: 6000 lbs.
Pump pressure: 2300 PSI (max.)
Ram stroke: 13-1/2''
Minimum height: 3-7/8''
Starting lift height: 15-3/4''
Overall dimensions:79''L x 39-1/2''W x 39-3/4''H
Mrdi
88 Carrera G50
Old 03-15-2003, 07:27 AM
Author of "101 Projects"
Wayne 962's Avatar
These are cool. The only problem is that you can't really work underneath the car too well when they are extended. For the 911, it's not so much of a problem, as there isn't much in the center of the car except the floorpan. But on other cars, access can be a big problem...
-Wayne
Old 03-15-2003, 07:34 AM
